Introduction: Filer Guide for Hand-Saws
Sharpening a saw can be one of the most "difficult" tasks for a woodworker. I built this guide for sharpening hand-saw teeth at the required relief angles, for both rip saw and crosscut saw.
Inspired in an old tool from 1987 hard to achieve (at least where I live) and using materials available to anyone, I show you the step by step to make it by yourself.
- It is very important to clarify that the files work only forward. Therefore, the force when sharpening only has to be in that direction and the backwards without pressing, thus, we will avoid premature wear of the file.
If you like the video please Subscribe to my Youtube Channel.
I would also apologize for my English as a non-native English speaker some terms are very difficult for me. Forward, Intractable!! I will be happy to answer any questions.
Step 1: Material and Tools
Materials
- Beech wood
- Elondo (African wood)
- Wood Wax
- Epoxy glue
- Wood inserts (Threaded)
- Double thread screw (4mm)
- Thread Screw (2
- Handle for needle files
- Hinge brass
- Saw file slim
- Finger nut (4mm)
- Wing Nut (6mm)
Tools
- Metal Cutting Saw
- File metal
- Mini Try Square
- Japanese Saw
- Stanley No 4 plane
- Caliper Mitutoyo
- Chisel
- Clamps
- Rasping rifler
- file metal
- Ruler
- Drill press
- Sanding paper
- Mini lathe proxxon fd150
Step 2: Guide Bed
Step 3: A and B Guides
Guide A:
For this guide I came up with the idea of using a brass hinge that I cut in such a way that on one side it served as a sliding guide and on the other to calculate the point of the wanted degree.
This guide is designed to sharpen crosscut and rip saw so I marked the different angles in the wood and pointed out with some small brass tips. To attach the "hinge" to the wood I used a 4mm double thread screw and a finger nut.
Guide B:
We have to make a support that can be adjusted in height since it will be the one which marks the size of the tooth. I made it in a simply way using a 5mm steel rod that I bent at 90º and incrusted into the top of the wood. I used a 6mm wood insert and a wing nut for fastening.
Step 4: Handle for Needle File
To hold the file I made a structure with Elondo wood, 2 steel rods and a handle for needle files. I leave the measurements that I used for a file of 15m, in the case of using larger files you only have to increase the length of the steel rods.
I cut and drilled the 2 pieces of wood. For this, I used 2 templates printed on paper that I attach in the Instructable. I marked the silhouette of the handle and with the help of a chisel I embedded it in the wood sticking it with epoxy.
I cut the steel rods with the right size for my file and threaded the ends to be screwed. This step is done with a mini proxxon fd150 lathe but you can also do it with a dril press. I made this step with a mini proton FD150 lathe, but you can also make it with a drill press.
Step 5: Montaje Final Y Conclusiones
To protect the wood I use transparent wax for wood and join all the parts of the guide with its corresponding screws.
I'm happy with the final result, it takes a little time to hold the saw blade and adjust the guide but then the process is very very fast.
This is just an idea and I'm sure many of you will improve it, I just ask that if anyone creates their own guide let me know!
