Introduction: Final Escape Room Project
For this escape room, the participant will be completing a word search that starts out as Thanksgiving themed and transitions to Christmas. After completing the holiday transition, it will be time for them to put their Christmas lights up. They must construct the Arduino Uno in order to begin their Christmas celebration.
Step 1: Arduino Code
int buttonState = 0;
void setup()
pinMode(12, INPUT); //push button
pinMode(13, OUTPUT); //red LED
pinMode(2, OUTPUT); //green LED
void loop()
// read the state of the pushbutton
buttonState = digitalRead(12);
// check if pushbutton is pressed. if it is, the
// button state is HIGH
if (buttonState == HIGH) {
digitalWrite(13, HIGH); //13=red light and "high"=on
digitalWrite(2, LOW); //2=green light and "low"=off
delay(500); //Pause whle the lights switch
digitalWrite(13, LOW);//red light is off
digitalWrite(2, HIGH); //green light is on
delay(500); //pause while the lights switch
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
} else {
digitalWrite(13, LOW); //If the push button isn't pressed, red is off
digitalWrite(2, LOW); //If the push button isn't pressed, green is off
delay(10); // Delay a little bit to improve simulation performance
Step 2: Hardware Set Up
- Connect either the red or green LED to J1 and J3.
- Connect the other colored LED to J16 and J17.
- Connect a push button to E3, F3, E5, and F5.
- Connect one 220 ohm resistor to D1 and F1.
- Connect the other 220 ohm resistor to D16 and F16.
- Connect the 1K ohm resistor to C5 and C9.
- Use a wire to connect I3 on the breadboard to digital pin 5V on the Arduino.
- Use a wire to connect A1 on the breadboard to GND on the Arduino.
- Use a wire to connect F2 on the breadboard to digital pin 13 on the Arduino.
- Use a wire to connect D5 on the breadboard to digital pin 12 on the Arduino.
- Use a wire to connect A9 on the breadboard to GND on the Arduino.
- Use a wire to connect B9 on the breadboard to B16 on the breadboard.
- Use a wire to connect F17 on the breadboard to digital pin 2 on the Arduino.
Step 3: How to Play
The player must complete the holiday word search attached below. Once completed, the player will be given the instructions needed to set up their Christmas lights and enjoy!
Link for Tinkercad: https://www.tinkercad.com/things/04b3CTgiJtA-final-project/editel
