Finding Direction, Distance and Navigating to a Distant Base by Stars.
Intro: Finding Direction, Distance and Navigating to a Distant Base by Stars.
by tonytran2015 (Melbourne, Australia).
Figure: The sky map for use in Northern hemisphere.
The method here uses stars for finding base city at a distance between 1000km to 9000km and for traveling to that base using constant latitude for final path.
It uses the stars passing overhead the base city and accurate time to tell those moments. Direction and distance to that city are directly observed from the stars. If no current longitudinal information is available and longer travel distance is acceptable then the user can also use this method to aim for base city on the final constant latitude part of the travel.
This is a back up or emergency method for people who may need to find out their direction to base and how to arrive there even when having no landmarks for current position. This is the case for:
A. People who are lost in the ocean or in a large desert with no reliable landmark. They need some method of orientation using minimal number of tools.
B. People drifted to an isolated island in the ocean after a tsunami !
C. Installers of long distance or satellite communication antennas wishing to aim their devices when not having any map.
Required information:
1. Selected star(s) for the chosen base city with the target point(s) underneath the star(s) reasonably close to the base city.
2. Longitude of the base city and time signal announcing GMT time to show the time at base city. The time signal may come from Broadcast or Marine Band Weather Radio.
3. or an accurate watch that allows determination of the true (not zonal) time of base city (Each minute earlier or later than intended time may cause a longitudinal error of 0.25 degree that is about 27km near the equator.).
STEP 1: Preparation Before Expedition
Figures 1 and 2: The sky maps for use in Northern and Southern hemispheres.
1. Search from the list of brightest stars (in descending order) for the brightest identifiable star that can closely pass overhead the base city (with acceptable error distance) and the approximate date for it to be seen in at midnight.
Example 1:
London is at (0°5' longitude, 51°32' latitude). In June, choose Eltanin (Gamma Draconis, 17hr 57', +51.5° declination) target point underneath the star is 0km from base.
Gamma Draconis is not in the top 20 brightest stars. It has be found from some star maps with many stars from the Internet.
Example 2:
Berlin is at (13°25' longitude, 52°30 latitude). In June, choose Eltanin (Gamma Draconis, 17hr 57', +51.5°declination), target point underneath the star is nearly 110km South of the city while the zenith of the city is 2 Moon's diameter from the star and toward the Celestial North . In December choose Gamma Persei (03hr05RA +53.5degrees declination, app magn 2.91) target point underneath the star is nearly 110km North of the city while the zenith of the city is 2 Moon's diameter from the star and toward the Celestial South.
Gamma Persei is not in the top 20 brightest stars. It has be found from some star maps with many stars from the Internet.
Example 3:
Mecca(39°45 longitude, 21°29 latitude) choose Arcturus in Boote (213.9RA, 19.2° declination) nearby location underneath the star is 230km South of the city while the zenith of the city is 4 Moon's diameter from the star and toward the Celestial North.
Example 4:
Manila (120°57' longitude, 14°35' latitude) choose Regulus, (Alpha Leonis, 10hr08'RA +12.0°declination) nearby location underneath the star is 280km South of the city while the zenith of the city is 5 Moon's diameter from the star and toward the Celestial North.
2. Work out the day for the star to be highest at midnight. The day is the same for all locations. It is almost Sep23rd plus the RA of the star multiplied by (365.25days/360°).
Example 1:
Gamma Persei is nearly overhead at midnight of
Sep23 + 3hr05*(365.25days/24hr) =
Sep23 + 46.92days = Oct23 + 17d = Nov 09.
Example 2:
The date of Arcturus in Boote is given by the table of bright stars in Step 2 as April 25th. Arcturus in Boote is nearly overhead at midnight of April 25th.
3. Learn by heart how to identify in the sky the stars associated with the base city. The accuracy and speed of this ability is essential to avoid mistakes under adversed circumstances. Users should not confuse between stars near the ecliptic and wandering planets nearby.
4. Practice determining the time when the star passes the vertical North-South plane at the base city on that date. It is midnight minus the local advance on GMT, which is equal to longitude multiplied by (24hr/360°).
Example:
Gamma Persei passes near Berlin (longitude 13°24') on that date ahead of mid - night GMT by (13°24')/(15°/hr) = 0.89hr, that is at
24hrGMT - 0.89hr = 23.11hrGMT = 23hr07GMT.
5. Every day later/earlier than that date, the star passes the location (60minx24/365.25) = 3.942 min of time earlier/later. Every month later/earlier than that date, the star passes the location 2 hours earlier/later.
This earliness is observable at all locations including your current one. When observing the star on another day, the earliness adjustment is needed.
6. If the Sun crosses the North-South vertical plane earlier/later than at base, the chosen star also crosses the North-South vertical plane earlier/later than at base by the same amount of time.
STEP 2: Field Application
List of 20 brightest stars. Additional, dimmer stars are also needed to travel closer to any arbitrarily given latitudes.
7. Identify the star and obtain the time signal from GMT. Work out the instant the star is overhead the base. (Alternatively, the moment the chosen star passes overhead the base can also be determined with an accurate watch from the time it passes the North-South vertical plane of current location and the advancement or retardment of local Noon relative to Noon at base.)
8. At that moment, the star is above the nearby spot close to the base. Every degree from your zenith is 111km distance from you. The direction to the star projected onto the ground gives direction to the chosen nearby location. To obtain more accurate direction to your base when the star does not pass its zenith, you can imagine another star at some diameters of the Moon on either North or South side of the RA circle from the chosen star and use it instead. Alternatively you can add some adjustment based on the differentials on a spherical surface to obtain the exact direction to your base.
STEP 3: Navigating by Only Stars.
9. To travel to the target location, aim for a location on the same latitude but more in the North-South direction of the current point. This makes the travel distance longer but ensures that the target is not missed in the final part of the travel. When arriving at that target latitude, aim at the target location. Keeping the selected star on the East West line when it has highest altitude will ensure that the traveller does not miss the target.
This method suggests a possible way used by desert travelers and an alternative for refinement of Polynesian method of navigation.
STEP 4: How to Find the Zenith Point.
The navigator has to hang a long plumbing line from a point higher than his eye level, stand away from it and look at the projection of the line onto the sky. The projection is a great circle arc through the zenith.
Looking at the plumbing line from many directions gives many great circle arcs intersecting at the zenith point in the sky. The navigator may have to note its relative distances to familiar stars and draw it and the stars on a piece of paper for future reference and cross checking.
This method requires a steady plumbing line and is suitable for ground travelers when resting at night.
You can also determine your zenith point by placing a small mirror at eye level, inclined by 45 degrees, next to a vertical line (such as a suspended plumb line, a vertical high pole, or a corner line of a high wall) and see where the line points to.
WARNING:
Do not attempt to look at your zenith from underneath a plumb line. The plumb weight may FALL onto your eyes causing serious injuries.
STEP 5: How to Locate Any Chosen Bright Star in the Sky.
1. Find out its position relative to the 20 brightest stars by plotting it on the star maps here from its RA and declination.
2. Work out steps starting from identifiable top 10 brightest stars to positively identify it through progressively nearer, easily identifiable, bright neighbours .
3. Use the sky maps here to practice finding it in the sky.
4. Examples.
4.1 Locating Eltanin:
Eltanin is found from star charts and the sky maps as the brightest star near to the point of one third of the way from Vega to Dubhe (There is no brighter star in the vicinity.).
4.2 Locating Regulus:
The table and star maps supplied here can be used to locate Regulus.
The broom shaped group of stars (Sirius, Canopa, Orion-Rigel, Betelgueuse, Procyon) identifies their elements. Betelgueuse-Pollux forms the hypotenus of the isoceles right triangle (Procyon, Betelgueuse, Pollux, Procyon, counter-clockwise) with Procyon at the right angle. Regulus is then one distant vertex of the rhombus (Procyon, Betelgueuse, Pollux. Regulus, Procyon, counter-clockwise).
STEP 6: Notes.
1. The local true time at the base city has the Sun crossing the North-South vertical plane at 12am. The zonal time (broadcasted by local radio and TV stations in the winter) is the true time advanced or retarded so that it differs from GMT by a whole number of hours.
2. The Sun crosses the North-South vertical plane before or after 12am zonal time by the difference between the local true time and zonal time. This amount is due to the excess or shortage of longitude to the nearest multitude of 15 degrees chosen for zonal time.
3. With an accurate watch still showing the zonal time at the base city, the longitudinal increment from that of base city can be worked out by the increment in the earliness of the crossing of the North-South vertical plane by the Sun. Each increment of 15 degrees in longitude corresponds to 60 minutes advancement in noon time.
4. Near to the end of the journeys, overland navigators may apply terminal homing using megafeatures such as familiar city silhouettes, mountain peaks, rivers, rock and soil formation, permanent cloud formations, existing or ancient tracks, vegetation boundaries or even smell from plants. Some traditional land travelers may even release trained eagles to home on prairies while some traditional ocean travelers may release islands spotting birds to home on islands.
2 Comments
tonytran2015 8 years ago
Thank DIY Hacks and How Tos for your comment. It makes me know what readers like.
DIY Hacks and How Tos 8 years ago
This is a great survival skill. Thanks for sharing.
