Introduction: What Is a Resistor?
  • A resistor is a passive two-terminal electrical component that implements electrical resistance as a circuit element. ~Wikipedia~
  • A device designed to introduce resistance into an electric circuit. ~Dictionary.com~
Basically, A Resistor is an Electrical Component that Reduces the Current Flow of A Circuit.
There are 3 Types of Color-Band Resistors
  1. 4 Band Color-Codes
  2. 5 Band Color-Codes
  3. 6 Band Color-Codes
In this Instructable, I am going to Explain Only about 4 Band Color-Codes. I may create another Instructable for the 5 and 6 Band Color-Coded Resistors.
Step 1: The Color-Code of the First Band of a Resistor
To Read the First Band, You have to know the Color-Code
Here are the Color Codes:
  • Brown - 1
  • Red - 2
  • Green - 3
  • Yellow - 4
  • Green - 5
  • Blue - 6
  • Violet - 7
  • Grey - 8
  • White - 9
Step 2: The Color-Code of the Second Band of a Resistor
To Read the Second Band, You also need to know the Color-Code
  1. Black - 0
  2. Brown - 1
  3. Red - 2
  4. Green - 3
  5. Yellow - 4
  6. Green - 5
  7. Blue - 6
  8. Violet - 7
  9. Grey - 8
  10. White - 9
The Color Code for the Second Band is Similar to the First Band
Step 3: The Color-Code of the Third Band of a Resistor
And to Read the Third Band, You can guess what you need to know.
Which is that you still need to know the Color-Code for the Third Band
  1. Black - 1 Ω
  2. Brown - 10 Ω
  3. Red - 100 Ω
  4. Green - 1000 Ω
  5. Yellow - 10,000 Ω
  6. Green - 100,000 Ω
  7. Blue - 1,000,000 Ω
  8. Violet - 10,000,000 Ω
  9. Gold - 0.1 Ω
  10. Silver - 0.01 Ω
For you new guys that don't know the meaning of the symbol 'Ω', It means Ohms.
Ohms is the SI Unit for Measuring Resistance.
This is the Multiplier Value for the Resistor
Step 4: The Color-Code of the Fourth and Last Band of a Resistor
To Read the Last Band in a Four Banded Resistor, You yet need another Color-Code.
The Following are the Color Code for the Fourth Band of the Resistor:
  1. Silver - ± 10%
  2. Gold - ± 5%
  3. Red - ± 2%
  4. Brown - ± 1%
  5. Green - ± 0.5%
  6. Blue - ± 0.25%
  7. Violet - ± 0.10%
  8. Grey - ± 0.05%
This is The Tolerance Value for the Resistor
Step 5: Calculating the Resistor Value
Now, To Calculate the Value of a Resistor you will need the Numbers from The Color Code
For Example We have a 'Brown-Grey-Brown-Gold' Colored Resistor, To calculate it we need to Find the Colors in the Color Code
  • Brown (First Band) : 1
  • Grey (Second Band) : 8
  • Brown (Third Band) : 10
  • Gold (Fourth Band) : ± 5%
First, Place the First number and Second Number Together. (1 and 8 = 18)
Second, Multiply the Number With the Multiplier (Third Band). (18 x 10 = 180 ohms)
So the Resistor Value is 180 ohms.
For the last Band, That is the Tolerance Value (which I may Explain in another Instructable), The Resistor have a Tolerance Value of ± 5%.
So it is an 180 ohms Resistor with 5% Tolerance.
