Fire Starter
Intro: Fire Starter
These can be used for starting fires in wood stoves, fireplaces, or camp fires. It is a good way to reuse junk mail and helps reduce the burden on landfills.
You'll need to gather your supplies
Junk mail
Toilet paper core tube
Melted wax. I use the wax from a wax melter after the wax has lost its scent. The wax should be in a jar a little over half as long as your junk mail bundle
STEP 1: First Step: Rolling
Roll the junk mail tight. Try to use enough mail that when tightly rolled it will just fit inside the tube
STEP 2: Second Step: Sleeving
Push the junk mail roll into the toilet paper tube
STEP 3: Third Step: Dipping
Dip the bundle into the melted wax. You need a taller jar so it will come halfway up the bundle
STEP 4: Fourth Step: Dipping the Other End
Rotate and dip the other end
STEP 5: Fifth Step: Finish
Set the waxed bundles to dry. These can be used singly or together to start fires
