Introduction: Firewood Rack-Trampoline Reincarnated
Here's an idea for demolished trampolines. Use the legs to build a firewood rack. We had a large limb break off of a Post Oak tree during a typical Central Texas thunderstorm. It landed right on our new trampoline! One of the leg bases was crushed, so I only had enough pieces to make one rack.
Step 1: Materials
You'll need:
(2) - leg bases from trampoline
(8)- straight leg sections from trampoline
(1)- 5' length of 1-5/8" pipe (chain-link fence line post)
(1)- 4' landsacpe timber or 4' treated 4"x4"
(4) - 3/8" x 3-1/2" lag screws
(4)- 3/8" flat washers
Tools:
Welder
Electric Drill
Drill Press
1-5/8 Hole Saw Bit
3/8" Drill Bit
Wrench
Step 2: Knotching the Braces
Use a drill press or pipe knotcher to cut 1-5/8" knotches in both ends of 1-5/8" galvanized pipe. I made (4) of these at 11" long at the shortest point. I have a wood stove that uses firewood cut around 16" long. If you use bigger firewood, you may want to cut these longer.
Step 3: Welding the Bases
Step 4: Weld Upper Braces
After tack-weldng the lower braces, lay the rack over & place one of the knotched braces down 2" from the top. Weld the (2) staight leg sections resting on the floor together & weld that to the leg base. Do the same thing to the other end, flip it to the other side & repeat (pic 1). Now stand it upright use a torpedo level to set the knotched brace clamp it in place & tack it to the staight leg section (pic 2).
Complete all of the welds where you tack-welded before. Be sure to have a fan blowing the welding smoke away when you weld galvanized metal.
Step 5: Attach Base
Cut landscape timber or treated 4"x4"approx. 17" Set under the bottom knotched braces & drill (2) 3/8" holes through each. Secure a 3/8" x 3-1/2" lag screw through each hole. I placed an end cap on top of each straight leg section.
