Introduction: Fireworks Gun
With one of the good fireworks you'd see at the 4th of July, this can be a really awesome gun, because however high those would go, is how for these would go, and it would do the same formation that it would do in the sky, but these do them going straight, like shooting a gun.
Step 1: Things You Need
Get these materials -
1. Fireworks
2. Doorbell button
3. A big container (Big enough to hold one of those fireworks that goes extremely high)
4. Two wires
5. 9v battery
6. Flashlight bulb
1. Fireworks
2. Doorbell button
4. Two wires
5. 9v battery
6. Flashlight bulb
Step 2: Making the Switch
cut a circle of foil the same size of the bottom of the container, then take off the bottom of the container and replace it with the foil. Cut one wire and connect it to the end of a battery, then with the remaining wire connect it from the other end to the doorbell button. With the other one lead it to the foil, like the first one.
Step 3: Testing the Bulb
Break a flashlight bulb, and twist the wires in it together, test it a few times to make sure it still works. Then once it does tape foil to the back of the bulb, and connect that to the other foil where the bottom originally was. Make sure the other part in the bulb is touching the circle of foil also so when the doorbell button is pressed the bulb turns on. Then fill it with fireworks and push the button igniting the fireworks.
