Introduction: First Aid Kit
designed this 3D printed first aid kit, because in the forest, camping or excursion, we are never safe from a small injury. easily transportable, this small kit will not take up space in your bag. very practical in the car too
tools need:
- computer
- fusion 360
- 3d printer
- PLA + filament
- and some stuff to put inside when it's print
files are provide, a parametric version as well (fusion 360 format) you can make your own style and all the settings (inside, outside, thickness, height, number of compartement inside and their size, ect )
Step 1:
FIRST STEP:
using fusion 360, create a sketch.
- From this sketch draw a rectangle of the desired size (this rectangle will represent the surface of your first aid box).
- Add an offset to this rectangle.
- extrude the rectangle and the offset created about 2mm height (this will be the bottom on the box)
- do a second extrusion of the desired height, but select only the offset (this will represent the total height of the box)
(this part of the first step contains everything you need to make the lid of your first aid box)
Step 2:
Third step:
Use your 3D printer to print the 2 object you have just made in fusion.
PLA works perfectly fine.
Use
2 perimeters
2 top/2 bottom
Infill 20% where it's need
No raft, no skirt no support needed
Print speed depend of your printer.
It should not be difficult to print
