Introduction: Rainbow Fishing Buoy Lamp
this is a wonderful lamp made of a old fishing buoy and is equipped with rope for practicing knot tying .
one old fishing buoy
one 2"x2" approximately 25" long
one 1" diameter dowl 30" long
wood glue
tools required: drill, saws (I used a chop saw, bandsaw, jigsaw), file, dremel, rubber mallet
Rope
paper towel role
LED light strips
clear packing tape
Step 1: Building the Base
cut 2"x2" in half
directly in the middle cut a 1" deep and 2" wide notch in both 2"x2" as shown in the image
they should fit together in t formation as shown in the image
Step 2: Making Hole for Lamp Post
place dowl in top of notch and trace a circle as shown in the image
drill multiple hole in the center of the circle
use a jigsaw to cut out the circle, the drilled holes will help you with this step. make sure when using jigsaw you do not cut the hole too big
use file and sand paper to shave down the inside of the circle until the dowl fits snuggly
Step 3: Glue Base and Post Together
put glue inside both holes and area where both notches connect
before glue dries put the bases together and push & twist pole into hole, if needed tap top of pole with a mallet as shown in photo.
let glue thoroughly dry
Step 4: Prepare Buoy
take buoy and use tools you have to cut small piece off the bottom as shown in the image
drill a hole at the top of the buoy off to the side near the loop as shown in the image
Step 5: Installing LED Lights
cut a paper towel roll to be about 1" shorter than the inside length of the buoy
wrap LED lights around paper towel roll leaving 2" to spare on each side as shown in image
tuck end without the plug into the end of the paper towel roll, feed the end with the plug through the hole in the buoy as shown in the image
Step 6: Prepare the Rope
cut rope in half if needed use match or lighter to prevent fraying
tie rope back together using double fisherman's knot as shown in the image
Step 7: Attach Buoy to Stand
slide buoy on top of stand and tie clove hitch and lash buoy to pole as shown in the image
attach LED light to the power cord and tape power cord to the stand stopping about 6" above the bottom
Step 8: Wrap Stand
wrap rope around the pole over the power cord to about 2" above the bottom
tie off rope to the bottom using a clove hitch
optional step: leave a foot of rope after the last clove hitch to practice knot tying as shown in the image
Make it Glow Contest
