Introduction: Fishing Light Back Pack
Home made an led lights back pack bag
Step 1: Wooden Light Mount
Trace the shape of the back pack on to 3-6mm wooden board. Cut 10mm smaller than the traced shape
Step 2: Complete Mount
Drill two holes both sides at the top of cut board.. approx 60mm apart.fit a suitable small bolt through the top hole either side through the board and light use small washers front and back. can either fit both bolts and washers to the board or mount the bottom bolt through both the bag and the board if you poke a hole through the back pack. Not needed if the cut mounting board is a tight fit. I Then stapled the bag to the wooden Mont inside and out.
Step 3: Fit the Board Into the Back Pack.
Place mounting board with fitted light inside the back pack. Zip/close the back pack or pin shut. I unsoldered the lights from the top of their adjustable/flexible chrome mounts poked a hole thru the bag behind the zipper so the chrome flexible light mounts could poke thru the bag material allowing for the back pack to zip closed completely. My bag had an inside pocket so I fitted the mount in there for stability. The stapled the bag to the wooden Mont inside and out.
Step 4: Staple the Mounting Board Into the Back Pack.
I then stapled the bag to the wooden Mont inside and out.
