Introduction: Fitting Dupont Connectors
One of the things that you can do yourself (and pretty cheaply) is to make your own connecting wires.
Making your own connecting wires means that you are free of the tyranny of the length and colour of connectors/jumpers that you need to buy, it is MUCH cheaper and you are never going to be short of a connector/wire again (of course, you still need wire, the connectors and the connector housing).
The cost is pretty fair, when you tote it all up:
I've bought wire for as low as $8 for a 10m roll (stranded copper in pvc sheath)
The Dupont housing (2P F2.55mm pitch) for $4.75 for a packet of 200 ($0.05 each)
The Dupont connectors (Female gold plated 2.54mm) for $10 for a packet of 200, Male (not gold, 2.54mm) for $7.90 for a packet of 200 ($0.04 each)
Dupont housing (1P F2.54mm pitch) for $2.86 for a packet of 100 ($0.03 each)
You'll need some decent wire cutters (mine cost about $16) and crimping pliers for Dupont connectors (mine cost about $12)
The Dupont housing doesn't care if the connector is male or female ... so they are interchangeable!
I've made dozens of connector wires so far, for connecting a 9V snap to a PCB, connecting LED to a pin header, connecting sub-boards and for making USB power cables. Once you get the hang of it, you will find it easy and rewarding.
Step 1: Gather Your Tools
A decent pair of crimping pliers, a wire stripper and a pair of side-cutters. A scalpel comes in very handy too.
You will also need some solder and a soldering iron. A Third Hand tool is also very handy.
To make a 9V snap with female connector, you will also need:
1 x 2P Dupont Housing
2 x Dupont Female Connector
1 x 9V snap (mine cost me $1.55 on eBay for a packet of 20 ... so that's $0.08 each!)
Step 2: Prepare the Wire
Get your 9V snap and trim about 5mm from the end using your wire strippers.
It's very helpful to then bevel the plastic/PVC sheathing on the end of the wire so that, when you insert the Dupont connector into the housing, it fits easily.
To do this, I simply took my scalpel and cut away the PVC kinda like sharpening a pencil.
The wire was already tinned, so if you are making your own connector where the wire isn't tinned ... tin it.
Tinning does two really useful things:
- it keeps the strands together in a tight bundle; and
- when soldering, the solder flows much better onto a tinned surface.
Tinning (in this context) is just applying solder to the wire without making a connection.
The bevel on the wire should be about 2-3 mm long.
Step 3: Prepare the Dupont Connector and Solder
Cut two connectors from the strip, leaving them on the strip. It is much easier to manipulate and much easier to solder when you leave the connector strip on board.
With the connector in an alligator clip on your Third Hand (or stuck in some plasticine for stability). You need to tin the inside of the connector where the wire will go. That is, between the fold-over wings of the connector and down to the handy little line in the connector body.
Use a reasonable blob of solder (leaving a blob of about 3mm) so that soldering in the wire is EASY ... don't make your life difficult!
Next, position the wire inside the U channel of the Dupont connector so that the beveled PVC is between the fold-over wings.
Apply your soldering iron to the blob of solder that you soldered in earlier. When the solder is hot, it will flow up the wire by capillary action. You don't need to add any more solder to make the joint good.
Take the piece out of the alligator clip and carefully wiggle the strip back and forth to take it off. If you wiggle it forward and back, it will put a lot of stress on the thin connection between the connector and the strip, you want it to do this so that it comes away easily, without resorting to cutting it with the side-cutters.
Your wires should now look something like the last image.
Step 4: Crimp the Connector
The first thing that I do is to give the connector a quick and light nip in the crimper to close the housing a little. If you don't then the wings are splayed out somewhat and the crimp can bend the fold-over wings the wrong way.
Next, the connector is placed in the jaws of the crimper (20-22) with the wings facing up (in the above picture, I have no idea how you are holding your crimper, so refer to the orientation above). The back of the connector should be wholly inside the jaws of the crimper with the non-crushing part wholly outside of the jaws. Close the jaws completely to make sure that the crimp is good.
I then put the connector into the next smaller anvil (26-28) and give it a light squeeze. I do this to make sure that the crimp is as tight as I can make it. Be careful not to completely crush the connector, you only want a light squeeze. I then turn the connector 90 degrees and give it another light squeeze. Honestly, I do this because I'm a bit obsessive.
Once you are crimped, the connector should look something like the last image.
Step 5: Shrinky and Fit Into the Dupont Housing
Now's the time to slip the small shrinky tube over the connector and the wire. That's right, do it now because doing it before you soldered would have made your life a lot easier ... and I'm feeling mean :P
Honestly, I should have put the shrinky on before I soldered ... but my shrinky is big enough to fit.
The Dupont housing has a little triangle embossed on one side of the plastic. I use this to indicate positive and I always orient my wire so that red is positive, red is at the bottom. That way I know which is positive when I connect, and I get to be a little bit more obsessive.
Slide the connectors into the housing until you hear a tiny click. If it doesn't click there's a couple of things that may have happened.
- you didn't remove enough PVC from the wire so it is a very tight fit or it won't fit.
- if you use a pin, you can lever the plastic tongue up and remove the connector from the housing. Remove more of the PVC insulation and try again ... be careful, the plastic tongue doesn't like to be wiggled to much.
- you didn't push hard enough. Sometimes, all I need to do is to manually push the little tongue down so that it catches the square tab on the connector.
If you hold the housing and give the wire a light tug ... the connector shouldn't move very much at all.
Now that that is done, slide the shrinky tube up so that it is flush with the housing and shrink it by lightly rubbing the hot soldering iron over it (being careful not to burn the housing, the wire, the shrinky tube or yourself.
Step 6: Job Done!
Well aren't we clever!
If you total up the consumable materials that we used in this project (the tools are not consumables, they are "plant and equipment") you have spent less than $0.30 AUD and made your own custom 9V battery snap connector. That's pretty cheap, considering that I've seen them for much more than that (>$1.00).
All that remains is to connect a battery at one end, and a blinky at the other to see the fruits of our labour.
As I said in the intro, I've made loads of these now and I feel confident in my skills here. Give it a go yourself, it won't cost you much to get going and you can impress your friends and attract gorgeous person(s) of the desired gender with your higher than average skills of connection ... you are now a LEGEND!
On a Budget Contest
1 Person Made This Project!
- ScienceDiscoverer made it!
33 Comments
3 years ago
What are the larger connectors called? I have the .1" or 2.54mm connectors but I want them for a wire size that is slightly larger. Are they molex connectors? Like the size found on computer power supplies.
5 years ago
Poor photos, a lot of unneded information, no instruction how to use crimper.
Reply 4 years ago
Terse comment, misspelled word, not constructive.
Reply 5 years ago
Hey ОлегК24, well, thanks for your time ... I guess.
7 years ago
I have a couple of comments about your instructions.
In general connectors that are made to be crimped are never soldered. Further, wires that are used with crimped on connectors are never tinned. You would normally only tin stranded wires that are secured with a screw or clamp or that are only soldered to a pin and not crimped.
If you solder a wire to a pin and then crimp the connector you will fracture the solder joint, the solder in the pin is extra material that is not supposed to be there and that will result in an incomplete crimp and an unreliable connection. That said there have been times when I have soldered a pin after I finished crimping it. That makes a very strong connection. However the connectors that you have shown in your instructions are designed to not need to be soldered. It is also pretty easy to get too much solder on the pin and then it will not fit into the housing.
Heat shrink tubing is not normally used with these connectors. No conductive surfaces are exposed once the connector is assembled. So no shrink tubing is required or desired. I use shirnk tubing with these connectors if I also sleeve the wires into a bundle of wires. Then I use heat shrink tubing to keep the sleeving from coming apart or moving.
The idea of using the arrow on the connector for your plus voltage is pretty good but the standard way of using the arrow is that the arrow always indicates pin one of the connector. It doesn't really matter electrically of course. It is just a standard way of doing things.
I salute you on your effort to do this instructable. I had thought about doing something like this. I am glad that you did it.
Reply 4 years ago
@cdtaylor51: I agree with not soldering, definitely not soldering before crimping! Thanks for adding that. I generally use heat shrink in place of housing for one- to four-wire groups, after that it gets chaotic..
Thanks for your thoughtful comments and advice cdtaylor51. Generally, I'm obsessive (is that obvious?) so I like to solder and tin as a matter of course rather than need. I've never had any problems with too much solder (that I can't wick out) or bad connections, but I certainly take your point. Thanks again!
Reply 6 years ago
I remember reading somewhere that it's actually detrimental to put solder in a crimp joint and it explained why but I can't find the reference now. The closest thing I can find is a NASA file on crimping where it says, "Crimping of solid wire, component leads, or stranded wire that has been solder-tinned, is prohibited."
http://workmanship.nasa.gov/lib/insp/2%20books/links/sections/201%20General%20Requirements.html
Reply 6 years ago
hey a-morpheus ... I'll make sure that I fully disclose whenever I sell anything to NASA :)
Reply 5 years ago
Not sure if this was what I was originally thinking about but I did find one reference about soldering by a guy who seems to be a crimping guru, saying soldering creates a mechanically weak point: http://tech.mattmillman.com/info/crimpconnectors under "What’s wrong with just soldering terminals?"
Pretty much agreed about the overkill of soldering, crimp technology was designed to obviate the need for that operation as well as improve joint reliability and flexability. The only application I can think of that suggests a crimped terminal be soldered is as a battery ring terminal (for portable marine use), lest the elements of corrosion infiltrate the barrel and make it an intermittent, degraded connection.
Question 4 years ago on Step 1
Could you please indicate what type of "decent pair of crimping pliers" you used and where you bought it? I haved used an SN-028B crimping plier, and I have a problem to insert the crimped connector into the dupont housings.
Answer 4 years ago
Did I understand well that you use multiple crimping actions for each connector to let it fit into the Dupont housing?
Answer 4 years ago
I bought the TH1958 (the cheap Taiwanese model ... at about $15. I don't know if Jaycar ships overseas, you'd have to chase them up for that. Good luck and happy crimping :)
Answer 4 years ago
I noticed that Jaycar sell 2 types of crimping tool (TH1958 and TH1834), which one did you use? Does Jaycar also ship to The Netherlands (Europe)?
Answer 4 years ago
I bought my crimpers from Jaycar ... the dupont connectors sometimes need to be slightly closed with the plier end of the crimper before they fit into the crimping jaws.
5 years ago
I agree with the others, you don't need the solder because if you get good at crimping and have decent pins they will hold securely. You can also skip the shrink wrap if you like.
I bought some pins on ebay. The male ones were ok i guess, but the female ones were too short compared to others i have seen, which means you have to have very little wire stripped so that male pins being pushed in don't touch the stripped wire.
Reply 5 years ago
Thanks dilbert99,
When I'm prototyping, I usually connect/disconnect fairly frequently (testing connections, reprogramming micro, etc.) so I like the security of having pretty durable connections ... also, with stuff that I offer for sale, I want to be very durable so that the end user hasn't any problems ... all that aside ... I solder because it is more reliable (in my experience). The first rule of engineering is minimum cost for the achievable goal.
Cheers
BrianO
5 years ago
Very good instructable. Followed this last night when wiring up my own-design 3D printer. Though being my first time I dun goofed and had to bodge the job a bit.
Oh well, got plenty of connections to practice on!
Though this time I'll avoid the solder.
Reply 5 years ago
Hey AcrimoniousMirth, good on ya. I've had no trouble with the solder connection, despite the nay-sayers.
Cheers
