Introduction: Fix Dolce Gusto Water Valve
The water valve in our Dolce Gusto machine got broken, so the water couldn't flow to the machine. After locating the problem, I disassembled the machine, modeled replacement part and brought the machine back to life.
3D printer
food-safe finish & brush for applying
Torx 10H scredriver
Step 1:
Get the model for replacement part from Printables.com and print it.
Because it will be in direct contact with the water that goes to your coffee, I recommend applying a food-safe finish.
Step 2:
Remove the water tank and unscrew 5 bolts from marked position. You can then remove the plastic back part.
Step 3:
Remove the black sealing ring and the broken part.
Replace it with the printed part and put it back. First the printed part, sealing ring after.
Step 4:
Put back the plactic back part and tighen with the 5 bolts.
Step 5:
Enjoy your coffee
