Introduction: Fix Rotating Mellow NF V6-Zone
The copper-ceramic Mellow NF heat break is a great addition to an E3D V6 hotend. Sometimes though it can happen that the part that screws into the heatsink can rotate around the ceramic tube. This is easy to fix luckily and mentioned in their description too.
- 16 mm spanner
- 7 mm spanner
- E3D style heater block
- E3D style nozzle
- The Mellow heat break
Step 1: Installing the Nozzle
First insert the nozzle all the way into the heater block until it cannot go further. The orientation of the heater block is not important. After screwing it in back off the nozzle a little (about 1/2 a turn would be enough).
Step 2: Installing the Heat Break
Now screw in the Mellow heat break from the other side and all the way until it reaches the nozzle.
Step 3: Tightening
Now keep the heater block from rotating using the 16 mm spanner while putting the 7 mm spanner on the nozzle. Tighten the nozzle a little. Make sure not to overtighten it since the threads in the copper heat break can deform. Putting pressure on it with just an index finger should be good enough.
Step 4: Done
Take out your heat break or leave it installed. Enjoy your aerospace grade heat break!
