Introduction: Fix Toe Shoe Holes Cheap & Easy
Instagram: withered_perception
So with the amount of stuff I do from day to day, I burn the toes out on shoes fast.
So here is an inexpensive cheap solution to fix shoe toe holes and prevent new ones!
Also works great with kids shoes, boots or anywhere else you eat threw footwear.
Step 1: Bag It.
Grab a bag a sack or what ever you heart desires.
Cut a hole for the toe or what ever part gets holes in your shoes.
Step 2: Tape
Tape like your life depends on it...
Not really... any painters tape will do... I go with blue cause frog tape is expensive and I'd rather save it for walls and windows.
If you want it to look good. I would tape around the toe to keep the flex seal in only the spots where I want it.
I personally don't mind a few drips or it covering the toe portion of the sole.
Step 3: Spray Away
Grab some flex seal and give it a good hit on the exposed area.
This will need several coats especially if it is on the soles of the shoes or boots or what ever your spraying...
Step 4: While You're Waiting
Take a few fall portraits for your portfolio.
Step 5: Time for Another Coat
Hit it again...
Step 6: Dry & Remove
Let the Flex Seal sit over night.
and simply pull off the bag. The tape will come with it.
Step 7: Done
All finished. Now get back to work!
