Introduction: Fix a Gumball Machine
This will probably be my shortest instructable ever.
So my daughter got this little gumball machine. The lever promptly broke because, well, it was cheaply made. Just a little extra plastic around the inside of the lever could have made this thing last more than a few minutes. Being 7 years old, this breaking was quite a disappointment and she didn't even get the gumballs out. Also being a smart little 7 year old she thought well I could wrap something around the inside...
I did one better, and just used my laser cutter to dash out a little insert to strengthen things up. Worked on the first try with just measuring the diameters with a ruler.
Laser Cutter (or handtools like a small saw and such)
2 or 3 mm plywood or mdf
Step 1: Design and Fabricate
Design the part needed to fix your item. In my case I just needed a little disk to insert into the lever to make it stronger.
Step 2: Fix
After cutting, place the part into the item.
Step 3: Return to Owner
I told you this would be short.
And that's it.
Enjoy.
