Introduction: Fix a Usb Hub Without Tools or Marks
For my first Instructable I chose something easy, fix a usb hub to the wood without tools or scratches.
Before continuing please excuse any grammatical errors, I do not have many chances to speak English in everyday life.
It is a removable fixing without traces like screw holes or remnants of glue, because you never know when you will need to change the use of furniture.
Step 1: You Will Need:
- Usb hub ;-)
- Sticker (bigger than the hub)
- Instant glue
Step 2: #1 Measure
Connect all the cables to the hub and check the place where you want
Step 3: #2 Disarms the Hub (optional)
Disarms the hub.
I made it to work more comfortably after but it's totally optional. In my case i didn't need tools, I did it with the hands
Step 4: #3 Place the Sticker
Place the sticker where you measure before, and yes i got Ubuntu stickers.
www.ubuntu.com
www.ubuntu.com
Step 5: #4 Apply the Glue
take the rear part of the hub and apply the instant glue, two drops are sufficient but it will var depending of the form of your hub.
Take care:
The instant glue could be hazardous substance, don't put closer to the eyes, mouth or nose.
Also is an is an electrical insulator, the cause of why i disarmed hub. I attempt to prevent the failure of the metallic pins.
Take care:
Step 6: #5 Place the Hub
Place the rear part of the hub on the sticker, do it very carefully not going to get the glue off the sticker.
Also take care for your fingers, you may finish sticked.
Step 7: #6 Join the Hub (optional)
If you followed the second step, now is the time to revert that. You have to join the parts of your hub.
Step 8: #7 Wiring
Put all the wires in their places and enjoy with your non annoying usb hub
