Introduction: Fix for Flash Player Security Update Install Failure on Windows 10
Fix for Flash Player Security Update install failure on Windows 10. Internet Explorer and Microsoft Edge update fail (easy fix). If you ran into an error after you had updated your Windows 10 yesterday, known as Error 0x80004005 you probably should know that Microsoft didn’t test the patch on Windows 10 before the release. At least a third of users have complained about the update fail, this new patched caused them and also the patch wasn’t build for Windows 7 users who currently use Internet Explorer 10 or 11. As I previously mentioned the update was only tested for Windows 8.x resulting in fails while updating it for Windows 10.
I did updated Windows 10 yesterday and it seems it’s working out for me but I guess it’s because I don’t use Internet Explorer or Microsoft Edge (a copy of Internet Explorer under a different name). This is the message you are going to get after installing the update:
There were problems installing some updates, but we’ll try again later. If you keep seeing this and want to search the web or contact support for information, this may help:
Security Update for Internet Explorer Flash Player for Windows 10 for x64-based Systems (KB3087040) – Error 0x80004005
So if you are getting this message there is a quick and easy fix. All you have to do is to download Windows 10 Build 10240 Patch (32-bit or 64-bit) and install it manually. But if you see the error, you can just ignore it, after all I know you are not using Internet Explorer or Microsoft Edge. Microsoft says that “other applications, such as Microsoft Office 2007 and Microsoft Office 2010, can invoke Adobe Flash Player in Internet Explorer.”
Just insure you select the file that matches your operating system and architecture (32/64 bit).
32-bit
http://download.windowsupdate.com/d/msdownload/update/software/secu/2015/09/windows10.0-kb3087040-x86_86b760ce3097391e6896df374d69aff46b769b02.msu
******************************************************* 64-bit
http://download.windowsupdate.com/d/msdownload/update/software/secu/2015/09/windows10.0-kb3087040-x64_ad0f78efb7b122fa9472dbb8050c4f358aceab49.msu
