Introduction: Fixie Cycle/Unicycle No Freewheel Drive Sprocket - Cold Welded
About: F/B group created for folks who might like to tell about their builds/projects. just type PROTO - TYPE - CHAT into find friends. Hope to see ya soon and hear about your new projects,fave builds or a…
So there I was building my multi gear unicycle - had got the basic build done and she was ride-able but a real pain to balance, I know I can work with this issue and if I build another multi gear I will leave the freewheel in - but for now ------
This build will work equally well for a Fixie cycle if you do,not have access to a welder.
Step 1: Factors
Ok - lets imagine we are looking into the sprocket through a transparent panel - depicted by the drawing. where you see the ball bearing is the usual position of the ratchet mechanism.
I do not have access to a welder (except for paying for the job to be done - living on benefits kinda discourages this), so I wanted a mega strong way of locking up the sprocket for my uni.
I had heard about JB weld but although strong I was not confident with it's impact properties i,e when trying to balance there could be high thrust into the JB that could cause it to break down over a short time - but! it might be a good retainer and re-enforcing addition.
Step 2: The Answer
The answer that presented itself was this - remove the ratchet mechanism - find a hardened insert that would stop motion in either direction.
Taking a lot of time and brain pain I came by the perfect insert - the ball bearings from the front wheel of the donor bike, two of these fitted perfectly into the cavity left after removing the ratchet. Super hard and free, no chance of slippage or deformation into the BB metal under thrust/impact.
I still wanted to exploit the JB potential so sent off for a pack.
The idea ended up like this - insert the BBs - fill totally around all internal cavities/teeth stopping any movement - re assemble the unit   and fill the cavity behind the locking nut also with JB, packing it around the bearings in there as well.
Blitz it on the bike and give her a go - - seems to be working really well so far.
No good for stunts on a uni or bike I would suggest but for road work there have been no fails of the unit so far.
See Ya
DZ
