Introduction: Fixing Moldy Caulking in the Bathroom
Close your eyes, try to visualize what the corners in your shower and around your tub look like. Are they pristine and spotless? If so, then then this post probably isn't for you. However, if they're anything like mine you might want to keep reading. As a contractor, I see 2 very common problems in a lot of bathrooms (including my own!) and in this post, I'm going to show you have to fix both.
The first is sloppily applied caulking. Amateur builders love to lay on heaps of silicone caulking in the bathroom. It covers a lot of sins and at first, it doesn't look THAT bad. The problem is that over time those big thick silicon lines are the perfect place for mold to grow. Ya, those black spots accumulating in the corner, those are mold, unfortunately. The more caulking you use, the faster the mold will grow and spread.
The second is that many people use white caulking in bathrooms. I get what they are thinking, there's lots of white stuff in the bathroom. The toilet, the tub, the sink, etc, it's all white. Here's the thing though, there are a million different shades of white. So there's a 99% that the white caulking isn't going to match anything in the bathroom. It's almost certainly at least a little bit off.
Let's fix both of them at the same time!
Step 1: The Video
I know many people prefer to read Instructable posts, but if you're more into video content then I've got you covered. Here's a link to this project in video form!
If you're in the majority of the people who prefer to read, then by all means, keep on scrolling. Let's start this fix this caulking!
Step 2: Supplies
It's a short list of supplies for this project. You'll need:
A tube of clear kitchen and bath silicone caulking (try to avoid the cheap stuff!)
A caulking gun
A roll of painters tape
A flat blade knife like a boxcutter or a razor blade
Step 3: Prep
The first step is going to be an easy one. Just remove everything you can so that you have room to work.
All of those shampoo bottles in the corner? Ya. They are going to have to go. Shower curtain? If you can, pull it down. The more room to work you the easier this job is going to be.
Next, give the whole shower a quick wipe down. You're trying to remove any loose dirt or water left over from the last time you used it.
It's probably a good idea to wait until after it been a while since your last shower or bath before attempting this project. The dryer, the better.
Step 4: Remove the Old Caulking
Here's where things get fun. You're going to have to cut out all of the old caulking. As far as I know, there's not easy, sure-fire way, to remove silicone caulking. It's just a matter of patience and dedication.
You'll need a thin blade, preferably a razor or a box cutter. I use a razor blade in a little holder because it makes it easy to hold and helps keep my fingers away from the blade. Please be safe when you're using any blade.
Then you're going to try to slide the blade between the deck of the tub and the caulking and slice all the way around the perimeter of the tub. You'll then do the same thing except you'll be sliding the blade between the tile or wall of the shower and the caulking.
Likely you won't get it all at first, there will be some residue, try to be as diligent as you can, and remove it all.
Sometimes you'll get lucky and once you get a good chunk of caulking pulled off you can use it to pull the rest off. This doesn't always happen though, mine just kept snapping on me :(
Once you've removed it all, give the whole area another good clean and vacuum.
Step 5: Apply Painters Tape
This step basically ensures that you're going to get a perfect application of silicone. It's also the step that most people skip or just don't know about.
You're going to take some painters tape and apply it around the perimeter of your tub and shower, masking off the area where you don't want the silicone to go. On the deck of the tub, you're going to apply it and leave it back of the wall by about 1/16 to 1/8 of an inch.
On the wall, you're going to apply it 1/16 to 1/8 of an inch above the deck of the tub. If done correctly you should have a thin, straight, unmasked line in the corner of the perimeter around your shower/tub.
While not strictly necessary I took the time to redo my entire tub surround as well. This meant doing the sides of the tub and where the tub meets the floor. I wanted to get rid of ALL of that nasty white caulking.
If you're going to be a perfectionist like me and do a lot of lines, consider breaking the process up into a couple of phases because this is a relatively time-sensitive job. Sometimes I'll do all of the vertical surfaces in 1 pass, and then all of the horizontal surfaces in another pass.
Step 6: Prep Your Silicone Tube
You're almost ready to start caulking, but let me give you a few tips first.
First, use clear silicone. It's much nicer than white silicone, and, if you apply it in a thin clean line it takes on the color of whatever surface you apply it to, which ensures an exact colour match. If done correctly it's basically invisible.
Second, make sure you buy a proper kitchen and bath silicone. They have anti-fungal agents that keep mold from growing on them. In my experience, it's usually worth it to pay the extra few dollars and get a high-quality silicone too.
Finally, third, try to cut the tip on the silicone tube to the same width as the line you're trying to apply it too. It will make the application a lot smoother and you'll waste less silicone.
Step 7: Apply the Silicone
Ok, time to load up that silicone into your caulking gun and start applying. Pick one corner, pull the trigger until caulking starts to come out of the end of the tube, and slowly work your way around the tub.
A light touch is best here, no need to lay down a ton of silicone, that's what you're trying to avoid here remember!
Don't beat your self up if you color outside of the lines a little bit, that's the whole reason you laid down the painters tape.
Step 8: Initial Wiping
After you've finished applying the silicone you're going to take your finger and simultaneously press the silicone into the corner and squeegee off any excess the whole way around.
Try to make sure you're applying a consistent amount of pressure and have a rag handy so that you can wipe off any excess silicone on your finger.
You'll probably wipe off about 3/4 of the silicone you just laid down, don't worry, that's perfectly normal. I like to do AT LEAST 2 full passes the whole way around the tub before I move onto the next step.
Step 9: Remove the Tape
Once you're satisfied you've removed most of the excess silicone it's time to peel back the tape.
Pick a corner and start peeling!
Be careful that as you peel the tape you don't accidentally rub it against anything because it's probably got a good amount of silicone still on it.
Step 10: Second Wiping
It's time for one last pass with your finger.
After the tape is removed your silicone line will have a hard edge on both the deck of the tub and the wall. In order to smooth out that edge and really blend the silicone out, you're going to do one last pass the whole way around with your finger. You don't need to press as hard as your first couple of passes, just enough to feather out the edge.
Step 11: Stand Back and Admire Your Work
Here's what my caulking lines looked like after I was done. They're basically invisible.
Not only are they much nicer and cleaner looking, BUT, because they're so much smaller there's WAY less surface area for mold to grow and accumulate. It should mean that these caulking lines stay mold-free for a long time
Step 12: Caulk the Corners (optional)
Let me preface this step by saying this: If your shower enclosure is properly waterproofed and your tiles are properly grouted, you DONT NEED TO CAULK THE CORNERS. Sorry for the caps lock, but I see this far too often and it's a bit of a pet peeve of my mine.
That being said, the grout in the corner of my shower was in pretty bad shape, so I had to re-caulk the corners. I would've much preferred not to, but in the interest of keeping the whole thing waterproof, I did.
I used the exact same procedure as before after the first application of silicone had dried.
I hope you enjoyed this post, let me know if you have any questions or comments and good luck re-caulking your showers!
37 Comments
2 years ago
I did this this morning!!!:) following ur steps. thanks
2 years ago
Love this idea! Additionally I incorporated rubbing alcohol to dip my fingers in and to clean up with before the caulk dries. With pretty much any silicone based caulk I've found that the rubbing alcohol helps prevent the caulking sticking to my fingers (as much).
2 years ago
Any ideas on caulking around the faucet and control? They are round and the faucet especially is difficult to maneuver around. Only think I can think of is using a plastic lid of some sort and cutting it out to fit around the faucet/control just a little bit bigger and using that as a guide....but how to hold it and caulk. Any ideas?
Tip 2 years ago on Step 4
Aceton can disolve caulking, if you have some small residues, it's great help
2 years ago
Wow, a totally new idea! I love it. I have tried many times to get a clean line and I always screw up. The idea of using painter's tape to mask it is brilliant.
2 years ago
Great instructions! I will add advice I got from a pro:
1. If you purchase "quick drying" caulk it will be harder to correct any errors, as the caulk cures quickly. Leave quick curing to the experienced professionals.
2. Great tip on the painter's tape, and be certain to remove it immediately. If the caulk is allowed to cure the tape will likely take your work with it.
3. Keep a very wet rag to clean your finger of caulk frequently, and a small container of water (I like the idea of soapy water) to re-wet the finger after cleaning with the wet rag.
I agree with the comment about avoiding clear caulk. I prefer the ivory colored; applied properly (with the painter's tape) it eliminates the appearance of irregular gaps between tub and tile.
Reply 2 years ago
I've never tried soapy water, I just apply a bit of soap directly on each finger and apply it like that. That way every time I feel the silicone starting to stick, I just move to the next finger.
Tip 2 years ago
The discovery of pneumatic caulking guns improved the quality of my caulking jobs significantly. Under $30 on Amazon, all the hesitation marks where the trigger has to be released and re-pulled are eliminated. One smooth continuous bead. Doesn't take much air pressure or a big compressor. Make sure it's regulated way down probably (around 10-15 PSI) or you'll have more caulk in front of you than you know what to do with. It will go as fast or slow as you want.
2 years ago
A couple of the things I was going to mention appear to have been covered. I'll make them anyway.
The directions on the packs in Australia say that the silicone must be pushed into the gaps by pushing ahead of the nozzle. A contractor who did a major repair/reno to my ensuite showed me that after the silicone is applied (say after you remove the tape) spray the area with a soapy water solution. Nxt wet your finger, then smooth the silicone with your finger. the silicone will not stick to your finger OR THE TILES and the job is done.
2 years ago on Step 12
Very clever. I look forward to trying this on any of my silicone caulking tasks.
Thanks
Tip 2 years ago
If you "Push" the tip while dispensing, you will not need to tape or go over with your wet finger much. learned this from professional caulker... cheers!
2 years ago
"Keeping your finger wet really helps." - I can second that. What works even better is to put a bit of soap into the water. You fingers almost fly over the silicon and create a perfectly smooth surface.
Reply 2 years ago
Most soaps contain citric acid which makes the silicone slightly porous, and therefore more susceptible to mould in the long rung. If you want to apply new silicone just invest in joint finish as well (spray can, e.g. from Soudal).
2 years ago
Bravo! A few pointers. I once had an upstairs tum that leaked, but when Turned the eater on, no leak. It turned out the weight of a person pulled the tub away from the wall enough to separate the old caulking...so, applying as you did, while standing in the tub is great. Also, mention drying time. Also, some silicon caulk actually dry faster if wet, I use a bottle sprayer with water and fine mist....look into this. Thanks for your hard work making this post! Cheers!
2 years ago
This a job that definitely achieves better results with practice. If you're like me and only calk every few years, this is a great tip. Thank you so much!
Thank you for the video. I like the tape idea. Makes your line nice and straight. Will be doing my tub soon and will use that idea
Great tips and well written. I would love to see you write an article on grout.
2 years ago
Nice ible. Use the caulking tip to "wipe" the excess caulk. If you learn to push the caulking gun instead of pulling it, you will forgo all the taping and get a better job in the end.
Tip 2 years ago
To prevent mold on caulking joint and other crevasses, I spray a solution of javel and water on them after each cleaning. I reuse old household cleaner spray bottle, rince them and fill them with water and a ounce or less of javel. I have been doing this for many years now with no damage or degradation of the silicone. But no mold, not ugly black spots!
2 years ago
Great description - not trying to be hip and trendy, just got on with it! I shall be trying this out as soon as I can find an open store selling silicone.
One tip regarding wiping: In the UK we get loads of free newspapers, and tearing a couple of pages from one into 4" squares gives you loads of one-use wipes!
