Introduction: Flash Drive Savers
About: A Northern Ireland based maker with a propensity to cause trouble and freshly constructed family.
A million (well a few) ways to short term skin your flash drive's tender circuits to save them from the ravages of your pockets...
Step 1: Skin It Up
smoke rollies or joints watever because the booklets of most skins contain a space below the folded skins perfect for this and your skins are left unperturbed...
Second pic shows where the drive can be pushed in to
Step 2: So Got Skins Then Skin Up...
Now people who roll should understand this and yes I use king size Zig-Zags ultra thin...
Right take your drive and lay it down lengthway in a kingsize skin (small might be big enough depending on the drive) and lick the gummed edge, then seal up to create a pocket. Now rip off the excess leaving half an inch or so above the drive. take another skin, lick and stick around the drive tight and spiral upwards using the whole length of the skin. now twist the end like you would a joint.
Step 3: So Time to Freshen That Breath...
Got any gum... may aswell share because flash drives are cheap but gum's cheaper
basically anything like wrigleys, empty the packet and slide the drive on in (I cut mine to size for this to make it snazzy)
Step 4: Be Lazy and Uninteresting...
Use a case for SD and XD card, needs to be a clip closed one...
Step 5: Sttring the Bleeder Up...literally
Tie a knot tight around the plug end of the drive and tightly wind string around to fully encase it, in the pic mine's got three layers... to finish loop in under the last one you made and tie it off
Step 6: Origami Stuff (kinda)
Basically the same as the skins but with a double fold at the top...
By the way I thought these up on my own but some may have been done so I don't want to hear oh you stole this and that... because people have done that an awful lot lately
