Introduction: FlashClip - the Handy Hat Clip for Pocket Flashlights
About: Hello! My name is Eitan, and I like to make stuff! I love circuitry, 3D printing, culinary arts, robotics, writing, photography, and gardening. I'm a high schooler in San Diego, and can't wait to keep making s…
Imagine this: Your engine starts smoking on the way home from watching the sunset in the mountains. You pull over and pop the hood, grabbing the small tool bag from your trunk. You are talking on the phone with the tow service, working with both hands to see what might have gone wrong with your engine, in the dark. You remember the flashlight you keep in your pocket for times like this, but how can you use it? You don't have a third hand, and you can't hold it in your mouth.
I experienced a situation very similar to that on a trip back from stargazing, and needless to say, it was not fun. If only I had a headlamp or some other way of securing the flashlight to my head, so I could see where I was working. That moment was the inspiration behind FlashClip, an easy way to convert a pocket flashlight into a head lamp, mounted on the brim of any-sized hat. In this Instructable, I will walk you through how I designed and built the first version of FlashClip, and how you can make one for yourself. Let's get started!
All you will need to make your own FlashClip is:
  1. 2 Medium-Size Rubber Bands
  2. 6 Meters of 3D Printer Filament (preferably PLA)
  3. Access to a 3D Printer and a Slicing Software
Step 1: The Design
First, I created some project guidelines for what I wanted the clip to look like. I wanted to be able to easily slide the flashlight in and out of the clip for quick deployment, while not being too loose as to be insecure during use. I wanted it to be slim so it could fit in a pocket or center console, and not require any special parts or hardware. I decided it would clip into the front of the hat brim, so it would be aimed wherever the user was looking. I eventually settled on a two-plate sandwich design that gripped the flashlight during use and then stored it small for storage. Besides efficiency, the sandwich design allows for any size flashlight to be used, even longer ones that house multiple batteries.
Step 2: Measurements
I started by measuring my flashlight, a very common generic one that I was gifted to keep for emergencies. The flashlight measured to be 3.5 inches long and just shy of 1 inch in diameter. I then grabbed one of my baseball caps and measured the width of the brim, which was 2 millimeters thick. I noted down my measurements and then jumped into CAD.
Step 3: Autodesk Fusion
For this project, I decided to use Autodesk Fusion, an easy-to-use CAD software that I've been learning to use. I love Fusion because it's super easy to create multiple-part designs, and it has great support for the 3D printing slicer I will be using.
Step 4: The Basic Shape
I started by creating the basic shape of the clip. I decided the spacing between the body and the clip arm would be 2 millimeters wide, and that the whole clip would be 3 inches long. That way, it would be slightly smaller than the flashlight itself, while allowing it to protrude out on either side.
Step 5: The Contour
To give the clip a better grip on the flashlight, I added a slight curve to the inside of the clip. This ensures that the flashlight remains centered in the clip and won't slide around side to side under use. I created the curve by drawing a sketch on the side and then using the "extrude" tool.
Step 6: The Sandwich Plate
Next, I created the second part of the clip. I mirrored the curve on the first part of the clip and shortened it to 2 inches. I shortened the second piece so that there would be access to the focus ring and the power button the light, for adjustment during use.
Step 7: Rubber Band Grooves
To keep tension on the two parts of the clip, the rubber bands would run around, forcing them together. To prevent them from slipping off the clip, I added a set of grooves that run along the top and bottom pieces.
Step 8: Bevel
To make for easier printing later, reduce stress on the rubber bands, and to remove any possibly dangerous corners, I added bevels to the edges of the design.
Step 9: Clip Notch
For a finishing touch, I added a small notch to the end of the clip. This provides some additional tension to the brim of the hat, and reduces any wiggling around that might happen.
Step 10: Slicing
From Fusion, I exported the model as an OBJ file and loaded it into CURA. I went with a layer height of 0.2mm and set the infill density to 20% for strength, since the clip would be under mechanical stress during use. I designed the model so that there would be no overhangs steeper than 45 degrees, and both have flat faces on each end so that they can be printed flat and upright together on the bed. I added a raft for some extra bed adhesion, and hit "Slice".
Step 11: Printing
I loaded the G-Code file onto my micro SD card, and got to printing. I decided to go with PLA for this print, as the clip will need a little bit of flexibility but also some rigidity so that the clip doesn't wear down as much over time.
Step 12: Assembly
Once it was done printing, I removed the raft from the parts and slid the rubber bands into the grooves. I wrapped the rubber bands around 3 times each for added grip on the flashlight because mine is on the smaller end, but depending on the size of your light, you can adjust the band strength.
Step 13: Finished
With the clip done, I slid in my flashlight and mounted it on my baseball cap for a test. It worked super well! I could not shake it off of the brim, and the whole time the light was steady and didn't even shake in the clip. I tried two different configurations, one with the flashlight on the underside of the brim, and one with the flashlight ontop. I will say that the flashlight mounted under worked better for me because it was more stable, but if you're using a larger light, it might get in the way. I really love the way this project turned out, and now I have a helpful new addition to my preparation kit. I think this is a pretty handy little gadget, and I'm excited to see what the community thinks. I have included all of the files if you would like to print one for yourself, or make any adjustments. Thanks for reading!
