Introduction: Flashdrive: Cool Sawed-off USB Wire (actually a Hidden Flash Drive)
its a cool flash drive hidden as a broken USB wire : )
please vote for me and like so i may have a shot in the contest thank you leave comments and i'll help all the time
Step 1: Materials
Materials (all house hold items )
less then $15 in total  for a cool  4 GB
- sharp box cutter
-set of handy tools (small screw drivers ) (optional but makes life easier)
-small flash drive (i used pny 4 gig cause its light weight and easy to take apart not even a single tool needed other than fingers )
http://www.google.com/products/catalog?hl=en&q=pny+4gb&sqi=2&cid=17908996546780696352#p
the one i used
-glue
-heavy books
and obviosly a used usb cable (its ok and even better if it doesn't work)
every thing is pretty cheap
Step 2: Flash Drives (the One That Is Highlighted Is the Best to Use and I Used That One )
the one that is highlighted is the best to use and i used that one
Step 3: Cutting
cut the sides of the usb cable
Step 4: Removing
Remove the guts of usb everything must go except  for the casing (obvious)
Sorry no picture :(
Step 5: Insertion and Completion
Put your own flash drive in and then use Elmer's glue to seal everything up and press and hold tightly.
*********************please read the next step right after putting the glue***********************
Step 6: Finishing Up
Put the USB on on book or flat floor then pile heavy books on it so it will be pressed. then take it out 2 secs later and wipe excess glue and then put it back , leave it for 30 minutes.
Step 7: Finished at Last!
Now enjoy please vote for me and like so i may have a shot in the contest thank you leave comments and i'll help all the time
