Flashing L.E.D. Using 555 Timer
Intro: Flashing L.E.D. Using 555 Timer
I was trying to put in a video but it didn't work for me, so here is a link to YouTube http://www.youtube.com/watch?v=9rS9nFG8xdI
This is a detailed instruction showing how to build a flashing L.E.D. using 555 Timer.There is no knowledge of electronics required in order to complete this project.
All the parts needed are listed, priced and links to them are also included.
There are two sets of pictures, the top shows the progression of the project and the bottom shows each step individually.
This is my first instructable and it is also an assignment so please leave comments.
Thank you.
STEP 1: Parts List
Here you will find a list of all required parts, their pictures, prices and where to get them.
There is also an excel file attached.
1. Breadboard
2. 9v Battery
3. Battery clip
4. Jump Wires
5. 555 Timer
6. Capacitor 1μF
7. Resistor 1k Ohm x 2 (brown, black, red)
8. Resistor 470k Ohm (yellow, purple, yellow)
9. L.E.D.
Time needed to finish this project: 5 - 10 min.
All the above parts can be bought at http://radionics.rs-online.com/web/ next day delivery (Ireland).
1. Breadboard
2. 9v Battery
3. Battery clip
4. Jump Wires
5. 555 Timer
6. Capacitor 1μF
9. L.E.D.
STEP 2: 555 Timer Pin - Out and Breadboard Layout
First picture shows a pin-out for the 555 Timer. This will be needed in order to connect the chip.
The second picture shows how the paths in the breadboard are connected.
STEP 3: Putting All Together
CAUTION !!!
This project contains small parts which can be ingested or inhaled, so keep away from young children.
Make sure to push all the parts in to the breadboard that they make contact with it.
1. Place the 555 Timer chip in the middle of the breadboard, make sure to put it in the right way round other wise when you will connect the battery the chip will burn.
2. Using short length of jump wire connect Pin 1 (negative) to the bottom row of the breadboard (ground).
3. Connect Pin 8(positive) to the top row of the breadboard (VCC).
4. Take another length of jump wire and connect Pin 4 with Pin 8.
5. Identify the legs on the capacitor C1, the short one is the negative and the long one is positive. Connect the positive leg to Pin 2 and the negative leg to the ground (GND).
6. Now connect Pin 2 with Pin 6 using piece of jump wire.
7. The resistors can be connected either way round. Using the 470k Ohm (R1) resistor connect Pin 6 with Pin 7.
8. Take the 1k Ohm (R2) resistor and connect Pin 7 to VCC.
9. Connect one end of the second 1k Ohm (R3) resistor with Pin 3 (output) and any empty row on the breadboard (this resistor will be connected with L.E.D. in the next step).
10. Identify the legs on the L.E.D., short one is the negative(-) and the long one is positive(+). Connect the positive leg with the resistor and the negative leg to the GND.
11. The final step is to connect the battery clip, the red lead to the VCC and the black lead to the GND. Connect the 9v battery and enjoy the effect.
77 Comments
JimTheSoundman 1 year ago
William Stell 2 years ago
rustrumek 4 years ago
FusionSource 5 years ago
toxin543 5 years ago
JezrelV 5 years ago
mbärtender 5 years ago
When I was going through google images I came across this post and noticed the wrong capacitor symbol was used. To help educate you, and those reading this page I have included a link with symbols. There are 2 types of capacitor symbols. Polar and Non-Polar. A polar symbol should have been used. Please use this page as a guide for your future schematics.
SparkFun Schematics
https://learn.sparkfun.com/tutorials/how-to-read-a...
SomehowB 5 years ago
in the schematic it should show the polarized (i always think electrolytic) capacitor and then there's no need to 'identify legs' instruction, 'cause whoever uses them *should* know @ least how to 'search-engine' determine polarity of a capacitor.
sorry, i started with on a negative tone...
thanks for the schematic, man! good job.
one suggestion, though...
the legs of the IC r numbered 1-8 kind of sequentially. on the diagram 1 and 5 r next 2 each other. it's kind of okay in general, but for a dummy like me would b nice[er?] 2 show pins in natural order vs this random 1. that would help people with connections... i feel like.
Smoog 8 years ago
Diamondc15 5 years ago
Connor Irwin 8 years ago
How do I make the LED flash faster?!
magnus7 6 years ago
I don't have a 1µF capacitor. Will a 4.7 work?
EFDG123 8 years ago
I doing it's don't but i smell not good?
like fire in led.
azharko 7 years ago
does one need a programmer to program a 555chip and also can a 555 chip be programmed using a programmer like arduino ? thanks.
555 chip is an analog chip which means it cannot be programmed using a computer
bjefford 7 years ago
The 55 chip is a collection of logic gates which allow you to set a cycle of on/off for the output pin. The greatest extent you can use a 555 is to make an LED flash or to add a timing function to a project. Smarter programmable chips like the processor in an arduino have a similar internal structure but are many times more complex.
https://en.wikipedia.org/wiki/555_timer_IC
*555 not 55
