Introduction: Flashing Micropython to ESP32 Minikit(MH-ET LIVE)
Had some issues with this board and solved them so this instructable ( mini-size ) will help you saving time .
Normally flashing micropython to an ESP32 is a piece of cake but this one took me a full day :-)
ESP32 minikit AKA MH-ET LIVE
220 Ohm resistor
wire , wire wrapping
Step 1: Solder the Headers and Connect the Resistor
To enter flash mode GPIO 0 should be kept low during power-up . To be on the safe side I measured my other ESP32boards ( they have a boot/flash button) and found out that when the boot button is pressed GPIO 0 is tied to GND via a 220 Ohms resistor so I copied it .
Erasing flash/installing Micropython can be done via Thonny IDE or the well-known ESPTOOL.py .
Here's how :
- solder your pins or headers , the board is fragile and one-time-soldering is recommended !
- connect the 220 Ohm resistor between GPIO 0 and GND as seen on the photo
- follow intructions :click here :-)
Step 2: Apres-Flashing ....
After you installed micropython removing the resistor should give you a nice board running micropython ...
It worked but there were a few issues :
- the board did not execute main.py when disconnected from the computer ...
- pushing the reset button on the board gave this nasty message :
rst:0x1 (POWERON_RESET),boot:0x6 (DOWNLOAD_BOOT(UART0/UART1/SDIO_REI_FEO_V2))
waiting for download
- Thonny IDE spitted out many many fault messages ...
Step 3: The Solution !
Investigation revealed that GPIO 0 should be high during power-up for normal operation .
I assumed that removing my resistor should be OK but it wasn't , a floating GPIO 0 can give unpredictable results ...
So just strap-up GPIO 0 to the 3V3 supply and you're done !
Assuming something took me a day but I hope this mini-instructable helps people saving time !
Happy Programming !
Bob
