Introduction: Flashing a Meraki / Accton / Fonero With OpenWRT Using Linux
This instructable will show you how to flash your Meraki / Accton / Fonero hardware with OpenWRT Linux using a Linux PC.
Author website: http://ruckman.net
Step 1: Download the Software and Set Permissions
Run the following commands from a terminal:
sudo apt-get update
sudo apt-get install wget
wget http://downloads.openwrt.org/kamikaze/8.09.2/atheros/openwrt-atheros-vmlinux.gz
wget http://downloads.openwrt.org/kamikaze/8.09.2/atheros/openwrt-atheros-root.jffs2-64k
wget http://ruckman.net/downloads/easyflash
wget http://ruckman.net/downloads/flash
chmod +x easyflash
chmod +x flash
sudo apt-get update
chmod +x easyflash
chmod +x flash
Step 2: Set Up for Flashing
Plug in your Unit (meraki/accton/fonero) to your Ethernet LAN port on your computer using a CAT5e straight through cable (8P8C).
Type (from the directory where the files are located):
ifconfig eth0 up
./flash
(note: If your unit is NOT connected to eth0, modify
the file flash accordingly, it should be eth0 but you can check by
issuing ifconfig)
ifconfig eth0 up
./flash
issuing ifconfig)
Step 3: Let the Flashing Begin!
Plug in the unit to power.
You should see something like this displayed:
No packet
No packet
Peer MAC: 00:18:84:80:67:1C (this will be the MAC address of your router)
You MAC: 00:ba:be:ca:ff:ee
Your IP: 192.168.1.0
Setting IP address...
Loading rootfs...
Sending rootfs. 6400 blocks...
Initializing partiions...
Rootfs partition size now 0x006f0000
Flashing rootfs...
Loading Kernel...
Sending kernel, 1536 blocks...
Flashing Kernel...
Setting boot_script_data...
Done. Restarting device...
Go get lunch. This will take 15-30 minutes, depending upon the flash
chip speed in your router. DO NOT INTERRUPT!
When it is done, the window will show Done.
No packet
No packet
Loading rootfs...
Flashing rootfs...
Loading Kernel...
Flashing Kernel...
