Introduction: Flashlight Safety Kit
A cheap and easy kit to hide money, provide fire, light, medication, etc
Step 1: What You Need
money
matches
pain killers
fever pills
fishing line
part of a paper clip
cheap flashlight from amazon
Canadian: http://www.amazon.ca/gp/product/B00SIVEOSM?psc=1&...
Step 2: Dissasembly
Extend the flashlight and twist while pulling the front of the flashlight to remove the body of the flashlight from the led. Then pry the circuit board off.
Step 3: Pills and Matches
Trim the matches so they will fit inside the small cavity. Then put the pills, matches and anything else you want into the cavity.
Step 4: Circuit Board
Push the circuit board back into the cavity
Step 5: Money
Reassemble the top then tape the paper clip bit (use it to open the cavity) onto the $5. Wrap the bill around the battery and wrap the fishing line around the bill. Put them into the flashlight and then reassemble the flash light. Be careful not to short circuit the flashlight.
Step 6: Finished
Check to see if the flashlight works and now your done
