Introduction: Flat Iron Fluffy Marshmallow Machine
Do you want a snack or dessert, but aren't sure what to do? Do you have marshmallows, stale or fresh, lying around, but no materials to make s'mores? Then this is the project for you.
This project will teach you how to turn a flat iron into a marshmallow machine.
There is an option to create an Arduino timer with a light, but it isn't required.
For S'more maker
- Flat Iron (dollar store or thrifted, something you can easily take apart)
- Large can (we used an 18.5 ounce)
- Duct Tape
- Linerless rubber splicing tape
- An old oven mitt for insulation
Tools
- Screwdriver
- Drill (or some other means to cut through the top of the can)
- Scissors
For Arduino timer (optional)
- Arduino nano + connecting cables
- 4 male-to-male wires
- 330 Ω resistor
- An LED bulb
- Circuit Breadboard
Step 1: Disassemble the Flat Iron
Using a small screwdriver, take the flat iron apart. Be sure to keep the internal electronics intact and connected to the heating pieces. Then feel free to throw out/repurpose all parts except the internal electronics and heating pieces.
Step 2: Drill/Cut the Can
Use a drill or other cutting implement to cut two holes in the bottom of the can opposite each other, each large enough for the heating pieces to be inserted into. Use duct tape to smooth over sharp edges.
Step 3: Add Heating Elements
Insert the heating elements into the top of the can. Add duct tape to the top to keep the things in place.
Step 4: Secure Heating Elements
Use the linerless rubber splicing tape to secure the heating elements at the bottom. Be sure to cover the parts that will get the most hot
Step 5: Wire the Breadboard (Optional)
Wire the breadboard and Arduino nano in this configuration. This will create the light that indicates the timer.
Step 6: Upload the Code (Optional)
This code will be a timer, and will cause the light on top to light up.
int Marshmallow = 0 ;
void setup() {
pinMode(3, OUTPUT);
pinMode(2, INPUT);
void loop() {
Marshmallow = digitalRead(2) ;
if (Marshmallow == HIGH) {
digitalWrite(3, HIGH) ;
delay(180000);
digitalWrite(3, LOW);
delay(1000);
digitalWrite(3, HIGH);
delay(1000);
delay(1000);
else {
Step 7: Cut the Mitt
Cut the oven mitt in half horizontally, just under the cuff.
Step 8: Sew the Edges (Optional)
Sew the edges to the cut cuff closed to prevent fluff from falling our and contaminating and food.
Step 9: Place Around the Device
Place the cuff upright around the can, with the cut edge on the bottom.
Step 10: Add Arduino Timer (Optional)
Tuck the Arduino into the cuff, or secure it in some other way.
Step 11: Secure the Cord
Secure the cord so it won't pull the electronics off. We tied it through the oven mitt loop, then secured the connection with the linerless rubber splicing tape.
Step 12: Give It Personality
Feel free to decorate your marshmallow machine. We added a ribbon, which helps secure the Arduino timer on the side, and googley eyes, which give it personality.
Step 13: Make Fluffy Marshmallows
Plug it in, and put in on top of a marshmallow to make it fluffy. If you made the Arduino timer, plug that in as well and press the button. If the flat iron heating components are shorter than the can, you may want to raise the marshmallow up.
