Introduction: Flat-Pack Chair
I was tasked with creating a Flat-Pack chair for my engineering class. To be "Flat-Pack," a chair must adhere to the following criteria:
- Made out of a single sheet of plywood
- Easy to cut with a CNC or Laser Cutter machine
- Be a (functional) chair
- Support a persons weight
- be comfortable
- other chair things etc etc.
- 4 foot x 4 foot plywood (3/4in thick)
- CNC machine
- fasteners (glue/screws)
- Upholstery (fabric, padding, etc.)
Step 1: Preliminary Research
The first step in this project (as well as any other project) is to conduct some research before you even begin to think about what you're going to make. For this concept, there are already a lot of designs out there so inspiration was easy to come by.
When searching for flat-pack chairs, there are a few main designs I came across.
- Lame, boring, uncomfortable stool
- Lame, boring, comfortable chair with back
- Cool-looking, incredibly uncomfortable / not functional chair
- Cool-looking, comfortable chair that uses too much materials
Finding a balance between form and function, as with all design challenges, is a formidable task.
Step 2: Brainstorm Designs
The next step in the process is to start actually thinking about what you want the chair to be.
I wanted some kind of a stool. Since the average surface area of a stool is pretty low, I figured I could use more wood for elements that I wanted to incorporate into the design side of things, rather than the practical side. If I were to do a chair, I would need more surface area for the back and armrests, which would use more wood.
Step 3: Prototype
There are a couple different ways to prototype your chair, my class used a cardboard model, followed by a scaled down CNC machine cut model that was more accurate to the original design. In this stage, the most important thing to do is early testing, see if:
- The chair supports a proportional amount of weight
- not inherently necessary, just see if it supports any kind of stress
- The chair has any racking / twisting
- All of the tabs fit correctly
- It looks how you want it to look
Step 4: Final Product
The last stage in the process is building the actual chair. Because of how much work you did beforehand, this step is absolutely the easiest. All you need to do is:
- Cut the plywood
- again easier with CNC machine
- Assemble the chair
- finishing touches
- any fabric / upholstery
- any fasteners (screws, glue, etc.)
- Test if it supports a person and / or is comfortable at all
And that's it! you have successfully made a flat-pack chair using
