Introduction: Flat Packed Traffic Cone
How to make a flat packed traffic cone.
Step 1: What Do We Need
The required materials:
- a polystyrene plate 50 x 50 cm (thickness 2 mm)
- reflex tape, self-adhesive white & red (width 2 mm)
length white: 4.5 m
length red: 0.5 m
The required tools:
- a meter
- a pencil
- a handsaw
- a buzz saw
- sandpaper
Step 2: The Outlining of Your Shape and the Sawing
Draw the correct shape as shown (picture1) and cut out the shape with a handsaw.
Do this two times so you have the same form twice.
In the middle of each plate you must become a cut with 2 mm wide.
This is done best with a circular saw, with the first plate you start from the top to the middle, with the second plate you start from the bottom to the middle.
Step 3: Apply the Strips of Reflective Tape
Make sure you stick the tape right, work from bottom to top, 6 cm tape, 6 cm nothing, 6 cm tape, ...
(do not forget the back).
For the upper top you use the red tape.
