Introduction: Flatline Paracord Keychain
Paracord Keychain with a black Flatline. Learn How to this Paracord Keychain with a Flatline. You will need these Paracord Supplies, 3 feet of Paracord, Key ring, 8 inch Piece of Paracord with the center removed, Scissors and a Lighter. I you want a 2 color Paracord Keychain, just melt the two ends of the Paracord together. With the Flatline, just weave it over under, over under, while your braiding the Paracord.
Step 1: Flatline Paracord Keychain - Step 1
Attach the Paracord to the Key ring like in the picture below. Fold the Flatline in half and put it at the top of the braid. Now with the first piece of Paracord lay it across the top, then bring the second piece of Paracord over the top of the first, around the back, and up through the hole created by the first piece of Paracord., Then pull it tight. Keep the Flatline under this braid.
Step 2: Flatline Paracord Keychain - Step 2
With the first piece of Paracord lay it across the top, then bring the second piece of Paracord over the top of the first, around the back, and up through the hole created by the first piece of Paracord., Then pull it tight. Keep the Flatline over this braid.
Step 3: Flatline Paracord Keychain - Step 3
Continue the braid, Lay the first piece of Paracord across the top, then bring the second piece of Paracord over the top of the first, around the back, and up through the hole created by the first piece of Paracord., Then pull it tight. Keep the Flatline under this braid.
Step 4: Flatline Paracord Keychain - Step 4
Continue braiding, bring the first piece of Paracord across the top, then bring the second piece of Paracord over the top of the first, around the back, and up through the hole created by the first piece of Paracord., Then pull it tight. Keep the Flatline over this braid, this time. Then pull it tight
Step 5: Flatline Paracord Keychain - Step 5
Continue the braid, weaving the Flatline over, under, until theres about a inch left in the loop (or however much you prefer). Then cut and melt the ends. If you have a Paracord needle you can run the tails back into the center.
Step 6: Flatline Paracord Keychain - Finished
Here is what you Flatline Paracord Keychain should look like. Now Learn How to make a Paracord Bracelet, check out the other great Paracord Projects. Sources: Paracord Keychain .net.
