Introduction: Flip Tail
This is a super cute hair due that's easy and ideal for short, medium, or long hair. I honestly don't wear my hair like this often, because I always end up ripping it. So let's go ahead and get started! Oh, and I'm using an American Girl Doll in this tutorial, but you can use your hair or doll hair.
Step 1: Gather Your Materials
You will need...
•1 hair tie
•1 hairbrush and/or comb
•Headband or Bow (optional)
•1 hair tie
Step 2: Brush, Part, Comb
Before you start, make sure that the hair you're dealing with is clean, brushed, parted, and combed. This will make it easier for you and your hair.
Step 3: Gather
First, gather your hair to one side of your hair, whether it's the left, right, or center.
Step 4: Brush
Then brush or comb your hair into your hand to make it neat.
Step 5: Tie Off
Then take a rubber band and tie off your ponytail, making it a little bit loose.
Step 6: Pull
Above the ponytail holder, make a hole in the hair by pulling the hair above the band or pushing your finger through it, as shown.
Step 7: Into the Hole
Then flip your hair into the hole, creating a look as shown.
Step 8: Take a Look
Step 9: Side View
Step 10: Pull
Then pull the hair at the bottom to tighten the ponytail.
Step 11: Overhead
Step 12: Side View
Step 13: Accessorize
I'm using a simple headband, and I do not recommend a bow. Bows will only block the view of your flip tail, but do as you please. Thanks for viewing!
Step 14: Check Them Out!
Please check out my other hair tutorials:
•Messy Bun
•Twist Bun
•Simple Braid
•Pigtail Braids
•Messy Bun
•Twist Bun
•Simple Braid
•Pigtail Braids
