Flip Flop LED Circuit
Intro: Flip Flop LED Circuit
This is a simple circuit based on transistor 2N 2222A and some resistors, there are 2 LED s and when one is on other will be off and this will be repeated in equal intervals of time
STEP 1: Parts List
2 x 2N2222 transistor
2 x 10k resistor (brown black orange)
2 x 390 ohm resistor( orange white brown)
2 x 100uf electrolytic capacitor
1 x blue LED (or other colors u like)
1 x red LED (or other colors u like)
battery ( 3 - 9v)
switch
battery ( 3 - 9v)
switch
STEP 2: Circuit Diagram
complete the circuit according to the circuit diagram,here i have used a common circuit board, there is a simple way to find the polarity of the LED ie, by looking for the flat part in the diameter of the LED the leg in that side will be negative
STEP 3: Conclusion
use safety scissors to decrease the length of the legs of components, do not use more than 9v which will make the transistor hot and some times burned,use alligator clips while soldering the transistors which will reduce the heat of the transistor thus saving it,comment if u have any doubts
42 Comments
thenerdygeeky 3 years ago
GuntherM1966 4 years ago
VinayK148 6 years ago
Can somebody please tell me about the dependence of frequency on the capacitance used. does it vary as the root of the capacitance or is there a linear relationship??
manicmonday 8 years ago
Would someone please explain in detail exactly how that schematic works to produce the flip-flop effect?
Thanks
thakshak 8 years ago
hi friend,
its called an oscillator circuit.
the capacitors are the real key to this circuit. The caps alternatively charge and discharge, which causes the two transistors to alternatively turn on and off.
check this circuit here. for better understanding.
HjalteL 7 years ago
Hello i think your link is broken.
If anyone want to see how this circuit works i have made a model of it:
http://tinyurl.com/jn9wcpf
NandiniG4 8 years ago
in this circuit, can i give a supply of 3.3 V or 5V? if I can then i have to change the value of capacitor and resistor?
I do appreciate your help, but instead of detail you have given me an overview and an animation. The animation shows what is happening in the circuit except nothing about the orientation or state of the capacitors. It doesn't tell me what the graphs at the bottom mean. What it really doesn't show is why these things are happening. Why does one capacitor charge while the other discharges? Why are both transistors not "ON" at the same time?
I feel this understanding is important to my continued advancement in the electronics field. To understand how is meaningless if you don't understand why.
I built this circuit and it works, but I still don't understand it.
consider the circuit from the link in my previous reply. c1 is discharged when left led is on. change the simulation speed(top-right corner of page) in the link for better understanding.
clayman987 11 years ago
peterochoa45 8 years ago
Yes, I did that... I thing is for the LED's so I think you can use down to 220 Ohms
clayman987 8 years ago
Its been a long time!
49percentGood 10 years ago
Mudbud 11 years ago
AnwarS1 9 years ago
hello..can this circuit use 3v of voltage?
Sure, I already tried it
wliu3 9 years ago
PlutoniumPurushoth 11 years ago
