Introduction: Floating Island
Hello, today i will show you how to build a floating island.
Step 1: Materials
You will need
Grass
Stone
(Optional)
Sapling
Cobblestone
Flowers
Buckets of water
Furnace bed glass panes
Wood planks
Grass
Stone
(Optional)
Sapling
Cobblestone
Flowers
Buckets of water
Wood planks
Step 2: Blocking Up
Start by blocking up untill you have the right height for your island, mine is about 30 blocks high.
Step 3: Building the Island
Place a stone square 3x3 on top of the tower of blocks you used to block up, then add 3 more blocks each side of the stone, see picture above, break the tower of blocks.
Step 4: Layer 2
Go around the sides of the stone copy the picture above.
Step 5: Layer 3
Build on top of layer 2, as in the picture above.
Step 6: Layer 4
Go around the sides of layer 3, like in the picture above.
Step 7: Filling the Hole in Layer 4
Fill the rest of layer 4 with grass
Step 8: Decorating (optional)
This step is optional. Build a small house on the island 5x4 with cobblestone and wood planks. Use glass panes for the windows. Plant a sapling on the island. cut a hole in the grass and fill it with water, place some lilly pads on the water. use bonemeal on the grass to make tall grass grow. Plant some flowers.
