Introduction: Floor Lamp
An adjustable rotating floor lamp.
Step 1: What We Need
LAMP KITS X 1
PLASTIC BOWL X 1
PVC PIPE:
1" X 1PC (IN HARDWARE STORE 10' EACH)
3/4" X 1PC
PVC FITTINGS:
ELBOW
1“ X 4PCS
3/4“ X 5PCS
TEE
1” X 6PCS
3/4“ X 1PC
CROSS
1” X 1PC
COUPLING
1“ X 1PC
CAP
1” X 1PC
BUSHING
3/4“-1/2” X 1PC
Step 2: Make Base
Cut 1" pipe and assemble base with 1" pvc fittings.
Step 3: Make Shade and Arm
Drill a hole on the plastic bowl.
Cut 3/4" pvc pipe and let it go through 1" cross. Cut two half inch pieces 1" pvc pipe to make two sleeves to connect them. Assemble arm with other 3/4" fittings and put wire and lamp socket kit.
Step 4: Install Arm on the Base
Connect the arm to lamp base with four 3/4" elbows (as the picture).
Screw or glue the pvc.
Suggest leave the 1" cross not screwed or glued, so you can rotate the arm to adjust the lamp higher or lower any time.
Put on lamp.
