Introduction: Floppy Disk Bank
store more then 1.44mb
Step 1: Materials
1. 6 3.5 floppy disk
2. small Flathead screwdriver
3. glue gun
4. razor bald
5. push pen
6. tape
3. glue gun
4. razor bald
5. push pen
6. tape
Step 2: Top of Bank
step 1. remove the metal tab of the floppy drive
step 2. use the small flat head screwdriver to pry open the edges.
step 3. after it is opened up, remove the black disk around the metal circle.
step 4. reassemble floppy disk, make sure to put the spring back in so the bank would be able to close.
Step 3: Bottom of the Bank
step 1. disassemble floppy disk
step 2 . remove black disk and the metal circle
step 3. push the push pen threw the center of the circle then use the razor bald to cut out the circle, make it smooth to prevent cuts. (be careful with razor blade)
Step 4: Floppy Disk Powers Go, Shape of a Box
glue 4 floppy disk to the inner edge of the bottom disk, then glue the top on.
remove glue spider webs and cover the bottom hole with tape.
make sure not to glue the metal tabs.
(Be careful with the hot gun)
Step 5: Every Penney Counts
slide back the metal tab to insert cash money!!!.
