Introduction: Flower Box
I made this project as a valentines gift. It shows time, and messages at a specified time and date. Also, an RGB button can be pressed to light up the acrylic. I've 3D printed the case using black and clear PLA filament.
Here's the materials I used:
  • NodeMCU V3 ESP8266 ESP-12E
  • Digital Capacitive Touch Switch Module TTP223B
  • Grove – RGB LED Stick (10 – WS2813 Mini)
  • 5V Relay Module SPDT
  • 7 segment display 4 digit LED module TM1637
Step 1: Hardware
See the pictures for the schematic and the hardware I used. Here's the components:
    • NodeMCU WiFi Board
      • Any ESP8266 board can be used. i used this since its what i have.
      • To use a switch to turn on the lights
      • Light up the acrylic
      • To turn on the lights
      • Show the time
    Connection to NodeMCU
    • 7 segment display 4 digit LED module TM1637 CLK → 12
    • 7 segment display 4 digit LED module TM1637 D10 → 14
    • 7 segment display 4 digit LED module TM1637 VIN → 5V
    • 7 segment display 4 digit LED module TM1637 GND → GND
    • Grove – RGB LED Stick GND → GND
    • Grove – RGB LED Stick VIN → 5V
    • Grove – RGB LED Stick SIG → 4
    • 5V Relay Module GND → GND
    • 5V Relay Module VIN → 5V
    • 5V Relay Module IN → 5
    • 5V Relay Module Common → 5V
    • 5V Relay Module Normally Close → Flower
    • Flower other wire → GND
    • Capacitive Touch Switch VIN → 5V
    • Capacitive Touch Switch GND → GND
    • Capacitive Touch Switch SIG → 13
      Step 2: Arduino Code
      Add the following libraries to your Arduino IDE:
      Here's the code I used with commented explanation. Copy this to your arduino IDE, upload and light it up!
      //Varaibles to change
      /*Get offset from <a href="https://en.wikipedia.org/wiki/List_of_UTC_time_offsets"> https://en.wikipedia.org/wiki/List_of_UTC_time_of...</a>
         ex: For UTC -5.00 : -5 * 60 * 60 : -18000 */
      const long utcOffset = 28800;
      int specialDay=16;
      int specialMonth = 2;
      String monthlyMessage = "lets dance to foreber";
      String yearlyMessage = "its been a happy year";
      //Wifi Credentials
      #ifndef STASSID
      #define STASSID "PutYourWifiSSIDHere"
      #define STAPSK  "PutYourWifiPassHere"
      #endif
      //Libraries to use the RGB LED Stick
      #include <Adafruit_NeoPixel.h>
      #ifdef __AVR__
      #include <avr/power.h> // Required for 16 MHz Adafruit Trinket
      #endif
      #define LED_PIN  4 //Pin the RGB LED Stick is connected
      #define NUMPIXELS 10 //Numbers of NeoPixels are attached to the module
      Adafruit_NeoPixel pixels(NUMPIXELS, LED_PIN, NEO_GRB + NEO_KHZ800);// Declare our NeoPixel strip object:
      //Libraries to use the 7 Segment display
      #include <TM1637Display.h>
      const int CLK = 12; //Set the CLK pin connection to the display
      const int DIO = 14; //Set the DIO pin connection to the display
      TM1637Display display(CLK, DIO); //set up the 4-Digit Display.
      //Pin connections
      const int buttonPin = 13; //pin connected to the switch
      const int ledPin =  5; //pin connected to the relay
      //Other Varaibles
      int numCounter = 0;
      int buttonState = 0; // variable for reading the switch status
      unsigned long previousMillis = 0;// will store last time LED was updated
      unsigned long previousMillis1 = 0;
      const long interval = 40000;
      int pressed;
      String curr_min;
      String prev_min;
      //Libraries to use the Wifi
      #include <ESP8266WiFi.h>
      #include <WiFiUdp.h>
      const char* ssid = STASSID;
      const char* password = STAPSK;
      //Libraries to get time from the internet
      #include <NTPClient.h>
      //UTC Time
      const long utcOffsetInSeconds = utcOffset;
      char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
      WiFiUDP ntpUDP; // Define NTP Client to get time
      NTPClient timeClient(ntpUDP, "pool.ntp.org", utcOffsetInSeconds);
      //To set Wifi Manager
      #include <DNSServer.h>
      #include <ESP8266WebServer.h>
      #include <WiFiManager.h>
      void setup()
        WiFiManager wifiManager;
        wifiManager.autoConnect("Love Watch");
        timeClient.begin();
        pinMode(ledPin, OUTPUT);
        pinMode(buttonPin, INPUT);
        display.setBrightness(0x0a); //set the diplay to maximum brightness
        pixels.begin();
        pixels.clear();
        digitalWrite(ledPin, HIGH);
        Serial.begin(9600);
        timeClient.update();
        String curr_min = String(timeClient.getMinutes());
        if ( curr_min.toInt() < 10) {
          curr_min = "0" + curr_min;
        String curr_time = String(timeClient.getHours()) + curr_min;
        display.showNumberDecEx(curr_time.toInt(), 0b11100000, false, 4, 0);
      //letters aside from k,m,q,v,w,x to print text on the 7 segment display
      const uint8_t a = 0x77 ;
      const uint8_t b = 0x7c ;
      const uint8_t c = 0x39 ;
      const uint8_t d = 0x5e ;
      const uint8_t e = 0x79 ;
      const uint8_t f = 0x71 ;
      const uint8_t g = 0x6f ;
      const uint8_t h = 0x76 ;
      const uint8_t _i = 0x6 ;
      const uint8_t j = 0xe ;
      const uint8_t l = 0x38 ;
      const uint8_t n = 0x37 ;
      const uint8_t o = 0x5c ;
      const uint8_t p = 0x73 ;
      const uint8_t r = 0x50 ;
      const uint8_t s = 0x6d ;
      const uint8_t t = 0x31 ;
      const uint8_t u = 0x3e ;
      const uint8_t y = 0x6e ;
      const uint8_t z = 0x5b ;
      uint8_t _char = 0;
      const uint8_t blank =  0x00;
      void send_message(String message) {
        if (_char > message.length()) {
          _char = 0;
        uint8_t  segment;
        uint8_t _display [3];
        for (int i = 0; i < 4; i++) {
          switch (message.charAt(_char + i)) {
            case 'a':
              _display[i] = a;
              break;
            case 'b':
              _display[i] = b;
              break;
            case 'c':
              _display[i] = c;
              break;
            case 'd':
              _display[i] = d;
              break;
            case 'e':
              _display[i] = e;
              break;
            case 'f':
              _display[i] = f;
              break;
            case 'g':
              _display[i] = g;
              break;
            case 'h':
              _display[i] = h;
              break;
            case 'i':
              _display[i] = _i;
              break;
            case 'j':
              _display[i] = j;
              break;
            case 'l':
              _display[i] = l;
              break;
            case 'n':
              _display[i] = n;
              break;
            case 'o':
              _display[i] = o;
              break;
            case 'p':
              _display[i] = p;
              break;
            case 'r':
              _display[i] = r;
              break;
            case 's':
              _display[i] = s;
              break;
            case 't':
              _display[i] = t;
              break;
            case 'u':
              _display[i] = u;
              break;
            case 'y':
              _display[i] = y;
              break;
            case 'z':
              _display[i] = z;
              break;
            default:
              _display[i] = blank;
              break;
        display.setSegments(_display);
        _char ++;
      void loop()
        unsigned long currentMillis = millis();
        curr_min = timeClient.getMinutes();
        unsigned long epochTime = timeClient.getEpochTime();
        struct tm *ptm = gmtime ((time_t *)&epochTime);
        int monthDay = ptm->tm_mday;
        int currentMonth = ptm->tm_mon + 1;
        if ( curr_min != prev_min) {
          prev_min = curr_min;
          Serial.println(curr_time);
        if (currentMillis - previousMillis1 >= 500) {
          previousMillis1 = currentMillis;
          if (curr_time == "000") {
            if (monthDay == specialDay && currentMonth == specialMonth) {
              send_message(yearlyMessage);
            else if (monthDay == specialDay) {
              send_message(monthlyMessage);
          if (curr_time == "2311") {
            for (int i = 0; i < NUMPIXELS; i++) {
              pixels.setPixelColor(i, pixels.Color(255, 0, 127));
              pixels.show();
            send_message("good nyt "); //change this message using small letters letters aside from k,m,q,v,w,x
          else if (curr_time == "630") {
              pixels.setPixelColor(i, pixels.Color(0, 0, 0));
              pixels.show();
            send_message("ganbate");//change this message using small letters letters aside from k,m,q,v,w,x
          else if (curr_time == "930") {
            send_message("hi");//change this message using small letters letters aside from k,m,q,v,w,x
          else if (curr_time == "1159") {
            send_message("lets eat "); //change this message using small letters letters aside from k,m,q,v,w,x
          else if (curr_time == "1830") {
            send_message("lets eat"); //change this message using small letters letters aside from k,m,q,v,w,x
          else if (curr_time == "959") {
            send_message("gud nyt ");//change this message using small letters letters aside from k,m,q,v,w,x
      //checks if the switch is pressed for 1 second. If yes, turn on the RGB Lights to Purple
        buttonState = digitalRead(buttonPin);
        if (buttonState == HIGH) {
          pressed ++;
          Serial.println("touched");
        } else {
          pressed = 0;
        if (pressed >= 10)
          pressed = 0;
          if (digitalRead(ledPin)) {
              pixels.setPixelColor(i, pixels.Color(255, 0, 127));//Change the color of the rgb lights here
              pixels.show();
          else if (!digitalRead(ledPin)) {
              pixels.show();
          digitalWrite(ledPin, !digitalRead(ledPin));
          Serial.println("on");
        delay(100);
      }<br>
