Introduction: Flower Pot Valentine
This is the perfect gift for anyone who is special in your heart because instead of store bought flowers and flower pot you are making it yourself.
Step 1: Get Materials
Flower Pot
Paint (your choice of colors)
Paint Brushes
Green Paper Clips
Wire Cutter
Pins with Pink Ends
Red and Pink Cardstock Paper with Hearts Printed on them
Scissors
3 Foam Spheres
1 Foam Pyramid
Puff Paint
Hot Glue Gun
Paint Brushes
Green Paper Clips
Wire Cutter
Pins with Pink Ends
Scissors
3 Foam Spheres
1 Foam Pyramid
Puff Paint
Hot Glue Gun
Step 2: Paint Pot
In this step your are going to paint your pot and you are going to want to put at least 2 coats of paint and for my flower pot i did two different colors but you can choose what colors you want to use.
Step 3: Puff Paint
In this step you will write a Valentines day saying on the flower pot using puff paint.
Step 4: Stems
unbend paper clips so that they look as if it is just colored wire, then take 2 paper clips and twist them together.
Step 5: Assembling Flowers
you will arrange and attach the cardstock flower petals which are in the shape of hearts by using several pins. Also you will hot glue the twisted paper clips. You will also need to take the wire cutters and cut off the extra pieces of the pins so that it isn't dangerous for others.
Step 6: Painting Foam
paint the foam pieces with a paint brush or you can use a sponge. also you will have to stick the flowers into the foam.
Step 7: Piecing It Together
in the final step you will arrange the foam pieces to your liking and them after you can give the beautiful flower pot to your Valentine.
