Introduction: Flower Puzzle Box
This is a puzzle box that can be locked and unlocked by twisting the flowers into the correct pattern.
I took inspiration from SKM on Youtube.
  • 0.115' thick wood (3 pieces of 23.5x11.5 dimensions, but could be squeezed into less)
Step 1: Cut Out/engrave All Pieces
cut out all of these pieces with a laser. (engrave flowers on a different layer)
AutoCad file is attached below
Step 2: Assemble Outer Box
You may need to use glue when assembling the outer box.
  • glue 6 sides to the inner ring and base (all pieces required are shown in the image above)
Step 3: Assemble the Locking Mechanism/lid
Using the pieces pictured above, assemble the locking mechanism by:
  • glueing each flower piece to a rod
  • securing it through the plank with 2 washer pieces
  • attaching the semi circle stopper, securing it with another washer
Picture #1 = flower pattern Picture #2 = Side view of locking mechanism Picture #3 = Inside of the box/pattern of semi circle stoppers
Step 4: Assemble Inner Box
Glue together the pieces for the inner box
Step 5: Slide Boxes Together and Mix It Up!
