Flowerpot Chicken
Intro: Flowerpot Chicken
DO NOT PREHEAT YOUR OVEN WHEN USING CLAY COOKING VESSELS.
This is a cheap and easy method of an ancient cooking technique known as clay pot cooking using a common terra cotta flowerpot and saucer. You can spend over $100 on a clay cooker at a gourmet kitchen gadget store, or about $20 at a garden supply. You choose. Some of you may already have the pot lying in your yard, garage or shed. Once you try this you will probably be cooking all kinds of things in it! N
First find (or buy) a large 12-14 inch diameter UNGLAZED pot and saucer. Clean any loose dirt off by scrubbing with hot water, but NEVER use soap on unglazed terra cotta. The taste will never leave.
STEP 1: Soak the Pot
Soak the pot and saucer in cool water for at least 15 minutes prior to putting it in the oven. Prepare all your food before and during the soak, so you can quickly fill it and put it in the oven Your oven MUST be cold when you begin or the rapid change in temp may crack your clay pot. Let the pot heat up gradually with the oven.
STEP 2: Prepare Vegetables.
Chop your vegetables while the pot is soaking. You can use whatever you like for this, root vegetables mixed with onions are always a nice base. This time I used leeks, bell peppers, garlic and red onions.
STEP 3: More Chopping.
Chop everything up and set aside. To avoid crying while chopping onions people suggest sucking on a piece of white bread, slicing under cool water, breathing through your nose... none of these work however, because it is a gas that is in the air coming in contact with your eyes, not the fine mist of onion juice going in your mouth or nose. Try wearing a gas mask, which can be purchased from most army supply stores.
STEP 4: Relax Your Chicken!
Massage your chicken until it is very relaxed. Coat the chicken liberally with seasalt, fresh black pepper and your favorite poultry spice rub (my sister swears by Paul Prudhommes Poulty Seasoning). Pour all your veggies in the saucer, plop your bird on top of that cozy nest...
STEP 5: Heat Things Up.
Cover the whole party with the flowerpot, and pop it in the COLD oven. Close the door and put the temp at 325f. degrees for 1 hour. You can also drop a remote thermometer sensor down through the hole and into the thickest part of your meat, whatever it may be, and set it to go off when it is about 10 degrees lower than your target temp. I put a pizza tray or cookie sheet under it to catch juices. You will likely have to remove all your oven racks to fit it in.
STEP 6: Grate Some Cheese.
Grate a mountain (about 1 loose cup) of your favorite hard cheese (asiago, romano, parmesan etc.) using a microplane if you have one, a fine shredder of any sort will do. A decent food processor will save you some time here.
When the hour is up (or your temp alarm goes off) open the oven, pull the pot out far enough to remove the top (using heavy duty burn protection, not just a kitchen towel, please). Sprinkle the cheese over the bird and cook uncovered for ten minutes more.
STEP 7: Gaze Upon Perfection.
You should end up with something like this at the end. Refrain from tearing into it immediately. Let it cool for about ten minutes so the juices don't squirt out. Your rice should be done just when it is time to cut the chicken.
STEP 8: Mmmm... Be Patient!
Mmmmm! Scrumptious Delights! Be sure to drizzle some of that gravy onto your rice as well.
STEP 9: Enjoy!
Add a side of asparagus, an artichoke or some other favorite green vegetable and you have yourself a simple, succulent feast! Ala cuisine!
STEP 10: Recipe
For those who work better with a detailed recipe, this is my recipe from the first time I used this flower pot at my father's house when I dug it out of the pile of dirt behind the shed. It varies from the instructable only in the extra vegetables used as a "nest" but the process and seasoning is very close.
Rupa's Flowerpot Chicken Geyserville
1 chicken, approx 4 lbs.
2 lbs red or white new potatoes
1 lb plum or roma tomatoes
2 med. onions (approximately 2 cups chopped)
2 med. green bell peppers
3-7 cloves of garlic (depending upon your taste)
1 tsp marjoram and/or thyme
1 tsp salt
1 tsp fresh ground black pepper (double if using preground)
1/4 tsp cayenne pepper
1/8 tsp nutmeg
2 sprigs fresh rosemary
3/4 cup red wine
1/4 cup Parmesan, asiago or other hard cheese, grated
Instructions:
In advance if possible set your chicken in an cold brine to soak--at least 30 minutes per pound, but not more than 8 hours total.
1 quart cool water
1/2 cup kosher Salt
1/2 cup sugar
12 peppercorns
6 allspice berries
3 whole cloves
1 sprig fresh rosemary
Mix the salt and sugar in the water, add the whole spices and submurge the chicken in the pot, cover and place in refrigerator's bottom shelf. Be careful not to let the water drip on anything! Place the pot in a shallow dish such as a pie plate lined with a few layers of paper towels to be extra safe.
Make a rub mixture of all dry spices (marjoram and or thyme, salt, black pepper, cayenne pepper and nutmeg).
Lay onions, tomatoes, garlic and green peppers into pre-soaked flower pot and pour 1/4 cup red wine over the veg mix.
Remove chicken from brine and dry with paper towels from under the pot, then lightly coat with olive oil and rub chicken liberally with spice mix, being sure to coat all over, inside and out!
Place chicken on the bed of vegies in the saucer, add a sprig of fresh rosemary and cover with the flower pot.
Place the whole thing into cold oven, turn temperature to 350* and bake for one hour without interuption.
At one hour open and remove top. Baste liberally with juices from under chicken.
Turn oven temp up to 500*
Sprinkle with fresh grated parmesan or other hard cheese of your choice and cook for another ten minutes uncovered.
Serve over brown rice.
1 tsp salt
1/8 tsp nutmeg
3/4 cup red wine
Instructions:
1 quart cool water
1/2 cup kosher Salt
1/2 cup sugar
12 peppercorns
6 allspice berries
3 whole cloves
45 Comments
spiritchat 9 years ago
I have heard that freezing the onions stops the gas release best. But i am not a cook which is why i am checking this out :D
Bubbler 16 years ago
rosehill 15 years ago
Goodhart 13 years ago
matthewabel 14 years ago
There's one or two recipes here on instructables.
archerj 13 years ago
This is a great recipe and 'ible!
This an awesome 'ible, love the oven, too.
killerjackalope 16 years ago
The plus is after cooking, the skillet will be perfectly seasoned.
rupamagic 16 years ago
Azulax 15 years ago
rupamagic 15 years ago
It took about one hour in two different gas ovens for me, and both times was completely cooked. In an electric oven I noticed it took a bit longer for the oven to actually reach 325 than with the gas stoves.
I would definitely use a thermometer to check the internal temp before deciding it is finished, as all ovens may vary a bit. I suggest you start the timing once your oven reaches 325f and not from when you put it in, since that warming up may vary greatly, especially in electric stoves.
I hope you will give it another try, as it really is a delicious and fun way to cook chicken.
I really love my meat thermometer, it cost my mom about $25 and has made my meat roasts, turkeys and chickens nearly foolproof every time I use it. It is one with a timer and an alarm you can set to go off when the probe reaches a certain temp. The probe is on a long wire lead so you can stab it into your roast (or bird) and it will constantly report the internal temp as it cooks. The suggestion is to stop cooking meat when the thermometer reads ten degrees less than your target temp (so if you set it to go off when it reads 160* the chicken will continue to cook for about ten minutes after you remove it from the oven and it will reach the desired 165-170f).
Some of the probe thermometers have preset target temps, so you just choose pork, beef, turkey, etc... mine lets me set the exact temp I am wanting and I think that is more practical. Just read the fine print when you shop for one. Mine is the "Pyrex Digital Probe Oven Thermometer/ Timer"
http://www.epinions.com/reviews/Pyrex_Digital_Probe_Oven_Thermometer_Timer
For some reason Amazon wants $69 for it now, but I noticed there is a seller listing it for $25 new in the sealed package on Amazon as well, so you just need to look around a bit for a good deal. I think mine came from Bed, Bath and Beyond.
I'm including a link to the exact thermometer/timer I have, as well as a generic cooking temperature chart I just googled for various types of meat. I have read that our safety guidelines for meats such as pork and poultry have changed in recent years, so you should do your own research and decide what you are comfortable with. Remember to set the thermometer to go off at 10 degrees less than target.
Meat Internal Temp. Centigrade
Fresh ground beef, veal, lamb, pork 160°F 71°C
Beef, veal, lamb roasts, steaks, chops: medium rare 145°F 63°C
Beef, veal, lamb roasts, steaks, chops: medium 160°F 71°C
Beef, veal, lamb roasts, steaks, chops: well done 170°F 77°C
Fresh pork roasts, steaks, chops: medium 160°F 71°C
Fresh pork roasts, steaks, chops: well done 170°F 77°C
Ham: cooked before eating 160°F 71°C
Ham: fully cooked, to reheat 140°F 60°C
Ground chicken/turkey 165° F 74°C
Whole chicken/turkey 180° F 82°C
Poultry breasts, roasts 170° F 77°C
Good luck!
Rupa
Of course, sometimes you can have a bird still frozen in the middle - always a good idea to give it a little extra thaw time.
Solderguy 15 years ago
ha3rvey 16 years ago
I would assume a gas mask would help the running nose problem, but I don't think it would help the tearing.
Also, I've worked as a prep cook at a couple restaurants, and I *never* got used to the fumes. I've chopped 40+ lbs. of onions a day for weeks at a time, and it always messed me up.
Dragontrap 15 years ago
donna477 14 years ago
