Introduction: Flying Wings
As part of my new project, I must make kinetic objects that react to the environment.
Before I make them react to the environment, I must figure out how to make them move as desired.
This is a tutorial about how to make wings flap.
My first kinetic object involves a dove that might not have to flap her wings in the end, but this mechanism seemed interesting and since I have to start somewhere, so I just did it.
- Rope 0.5 cm
- Wires of 0.75 and 1 mm
- 1 m craft wood stick of 1 x 1 cm
- Scissors
- Wire cutter
- Paper cutter
- Ruler
- Glue gun
- Multifunctional hand tool
Step 1:
- cut a 14 cm wood stick
- 2 cm from each edge cut into the stick a 1 x 0.5 cm space to fit the sticks that you placed the wire through
- use the glue gun to fix the pieces together
- cut to 6 cm wood sticks
- cut in the middle a 1 x 0.5 cm space
- place them at the edges of the 14 cm piece of wood
Step 2:
- cut a 25 cm piece of the 0.75 mm wire
- measure 3 cm and bend it downwards
- measure another 3 cm and bend it to the right
- measure 5 cm and bend it downwards
- 1.5 cm to the right
- 3 cm upwards
- 3 cm downwards
- 3 cm upwards
- bend the rest of the wire to the right
Step 3:
- cut two 12 cm wood sticks
- measure 7 cm from one end (it is going to be the down side of the stick) and make a hole in the middle of the stick
- do it for the two if them
- take the wire you bended previously and place it through the holes
- bend the 2 cm end of the wire downwards do it won't come out of the hole
Step 4:
- cut two 7 cm pieces of the 0.75 mm wire
- cut two 9 cm pieces of the same wire
- pair one of 7 cm with one of 9 cm
- bend one edge of the 7 cm pieces and the two ends of the 9 cm pieces until the form a loop almost closed
- place the loops of two different pieces one through the other and close them
- bend the wires to get the shape of wings flying
- as usually, I use netted wire to make the final object
See here how I do the netting:
Step 5:
- cut a 10-12 cm wood stick
- drill three holes that coincide with the middle of the loops from the wire that was placed through the vertical wood sticks earlier
- glue it in top of the wood structure made earlier
- place through each of the three holes a 20 cm piece of 0.75 wire
- secure one end end of each wire piece to the middle of each loop
- make sure that the wire does not slide from its place
- if necessary secure it with rope and glue
- tie the other end of each 20 cm wire piece to the wings as follows:
- the middle one to the middle of the wings
- the ones on the sides to the middle of each wing
