Introduction: Flying Witch
How it works?
You need basically three things for flying: speed, airfoil and control surfaces, you can see all of them in the witch.
Step 1: Plans
Here you have the plans, if you haven't a A0 printer don't worry, the PDF file contains the plans in A4 format.
Remember that parts 5,8 and 9 are control surfaces:
5 - Rudder
8 & 9 - Elevator
Step 2: Material
Depron, is a foam family product, lightweight and easy to cut.
Step 3: RC Parts
This instructable uses same parts than RC airplanes such a:
Motor (x1): http://www.banggood.com/Sunnysky-X2204-1800KV-Brus...
ESC (x1) (Electronic Speed Control); http://www.banggood.com/ZTW-Spider-LITE-PRO-Series...
Propeller (x1): http://www.banggood.com/2-Pairs-DALPROP-J6045-PC-P...
Servomotor (x2): http://www.banggood.com/3_7g-Micro-Mini-Servo-For-...
Lipo Battery (2S 600mAh x1): http://www.banggood.com/Giant-Power-7_4V-2S-600mAh...
And a receiver for your transmitter... haven't?.
Step 4: Tools
To cut depron: cutter or scalpel
To glue depron; Hot silicone gun
Reinforcing structure: Carbon fiber rods (3 mm)
Connect servos with control surface: Carbon fiber rods (2 mm)
For control surface hinge: standard adhesive tape
Step 5: Learn to Fly (if Necessary Only)
No, i don't speak about Foo Fighters song but it will be more fun if you know... Enjoy.
