Introduction: Foam Among Us Model
I have been seeing so many things about Among Us and I had some foam, so I made a model of an Among Us character. Warning: before you start, I would like to tell you that some foam is made from plastic, so the hot glue gun may melt it (I learned this the hard way). I will also be trying to make a video of how to make this sometime in the near future (I am planing on making around 12. One in each color, plus most of the hats that they have in the game). I am writing an instructable of how to make the hats, but it is not published yet.
Step 1: Cut Parts
Cut some foam out of these measurements:
•Body, 3/4 inch by 1 and 1/4 inch by 1/2 inch.
•Air Tank, 1/2 inch by 7/8 inch by 3/8 inch.
•Visor, 3/8 inch by 1/4 inch by 3/16 inch.
•Two Legs, 3/8 inch by 1/4 inch by 3/8 inch.
Step 2: Curve Edges
Curve the corners for each one I name.
•Body: Curve all the edges on the body.
•Air Tank: Lay the tank down on the bigger side and curve the four on the top.
•Visor: Do the same thing that you did with the air tank.
•Feet: Curve all the edges on the feet.
Step 3: Put Tank on Body
Take the air tank and put it onto the big side of the body with toothpicks and some hot glue.
Step 4: Attach Visor to Body
The visor may be a bit hard to attach with a toothpick like you did with the tank, so you can just use the hot glue to attach it.
Step 5: Attach Feet
Put some toothpicks in the top of the leg and hot glue it onto the body. Do the same thing to the other leg.
Step 6: Paint
This is exactly what it sounds like. Take some paint and paint the body. When you come to painting the visor, make it a light blue or white color. You may need to do a second coat of paint on the character.
Step 7: Done
You are done with this foam Among Us character. You may also add some props to the head by using toothpicks.
