Introduction: Foam Machine
Built this to spray a coat of biodegradable bleach alternative on my wooden deck to clean it. Spent $3.95 on a 3/8" OD 1/4 " ID poly tubing and $1.35 on a threaded vinyl nipple at the farm supply store. The kids loved the secondary use as a party foam machine!
The Motor is just an old leaf blower. I drilled a hole to fit the threads on the nipple after removing the blower tip. The bubble material is a men's dress sock made of sheer material. Hold the sock on with a hose clamp that fits your blower. Make a hole in the lid of the bucket for the hose. That's it.
Mixed a solution of 2.5 oz Dawn dish soap (plain) to 1 gallon of hot water. Filled; made sure the hose reached the bottom of the bucket. Elevated the bucket above and away from but, over the blower {{electricity and water = BAD folks....lets think.}}. This system uses gravity, not a pump, to move the solution. The fast moving stream of air over the hose adapter nipple in the tube helps draw the fluid but, not enough to draw from below.
