Introduction: Foam Apple Keychain Flash Drive...
well I got a buch of foam apple keychains and a bunch of tiny 256Mb memory sticks in a Uni package...
so the Usb apple was to come about...
or the US Bapple
quick easy and is more a general guide to hollowing out foamy stuff quickly
or the US Bapple
Step 1: Murder the Casing on That Stick!
we only need the guts of the flach drive so take the case off...
usually the case is held together by squeeze joints and just needs some carefull prying...
on mine it had a metal thign that spun around to reveal the male plug, to remover this I simply bet the metal bit but they're all different
Step 2: Now Have at That Foam
You'll need a sharp knife for this or even just scissors anything with cutting abilities...
Make an initial cut slightly smaller than your stick in width.
now you need to jam the knife or whatever inside and twist, coring your apple or item in general, occasionally pulling out to let the destroyed material out... once theres a fair space inside try putting your stick in and sizing it up (second pic 'half way there'), my apple was the lenght of the stick in diameter so I had to hack most of it's innards out...
Step 3: Done Already?
A little squirt of hot glue inside for this is helpful or the thing disintegrates after a while other than that enjoy squishy drives for life...
