Introduction: Foil Based Fractal Antenna.
Here are some more antennas you might be itnerested in: https://www.instructables.com/id/Antennas-TV-Wifi-and-etc/
Note: somehow while editing this instructable the text was lost. I have the original somewhare, I will try to find it later.
Original text per www.archive.org/:
You may also like: https://www.instructables.com/id/Dtv-Antennas-I-have-tried/, https://www.instructables.com/id/Yagi-foil-HDTV-antenna/
Worst case scenario, it makes an interest holiday decoration.
Step 1: What's Needed.
Piece of cardboard to act as a backing.
Tape to put it together.
Wire
1 coat hanger to make a form.
TV transformer.
Tools
Ruler that can measure in inches
60 degree triangle or equivalent.
Step 2: Make the Form.
Using a form will make it easier to make consistent folds for the antenna sections.
Take a coat hanger and cut an eight inch length out of the bottom part of the hanger. The rest of the coat hanger is unneeded.
Per the original author:
You will repeat this step for each wire. Each bend on the wire will be 60 degrees exactly as we will be making equilateral triangles with this fractal. I used two pairs of pliers and a protractor. Each bend will be made at the 1 marks. Make sure you visualize the direction of each bend first before making it! Use the diagram below to help.
Mine still needs a little tweaking, but you get the idea.
Step 3: Making Each Antenna Leaf.
Unroll 24 inches of aluminium foil. Cut the 24 inches of foil into three 8-inch pieces.
Cut each section so that each 8 inch section is half as wide.
Fold each piece of foil lengthwise in half. Repeat and repeat until you have a foil stick approximately a 1/8 to 1/4 inch wide.
Two of these will be the two long sections. We will use them in a later step
Four or the rest of these will be the fractals.
Take each of the four fractal sections and fold them like your form. This one still needs a bit more work.
Step 4: Putting It All Together.
Get an a 8x11 piece of paper or even better cardboard.
Tape down the two main strands so you can add the transformer.
Tape down the transformer.
The add the stars along each of the two strands.
Note: what is pictured is just a prototype, but you get the idea..
Step 5: Alternative Version.
Draw two long straight stips in the middle going lengthwise on the foil.
Use the original form to draw the fractals. (Just draw around it.
Do this four times till it looks like the fractal antenna.
Cut out the two sections. BE CARFUL THE EDGES ARE SHARP!!
Mount the sections.
