Introduction: Folding Utility Knife
In this Instructable I will show you how to make a 3d printed utility knife. this is useful to have in your pocket to open boxes, open packages or cut something.
You will need 1 utility knife blade
3d printed parts from this link https://www.thingiverse.com/thing:6066904
Step 1: Putting the Blade in the Housing
attach blade into the 3d printed blade housing. You may need to sand the housing to make the blade fit.
Step 2: Assembling Knife
in this step you need the blade and housing and the blade cover.
you will put the blade housing in between the cover. It may be a tight fit but if its too tight you can use a file or sand paper to help make them fit. Once the blade is in the cover you will want to aline the hole at the bottom of the knife. make sure it is allined because it will be important for the next step.
Step 3:
Put one clip on one side of the knife axle. make sure you do this or else you will need to take the axle out again. Put knife axle through the hole. Once the axle is through the whole you will need to put the second clip on.
