Introduction: Food Serving Robotic Car
Application Of the Car
Ø It can be used to pass Different object form one place to another like light weighted and short heighted
Ø Ex : from the smallest thing like from a pen , Pen Stand ,Phone , Bottle , Utensils {like the bowls , Cooked Vegetables , Snacks ets.}
Ø It usually can perform a role of transporter to pass any of the things from one place to another mechanically.
 So we will look at the highlighting features of this car
Ø This is Controlled by Wi-Fi hence this device is functional with any smartphone or computer with Wi-Fi capability
Ø As this uses lithium-ion battery it has the capacity of 4000mah which is sufficient for long time working
Ø Speed of Motors can be changed as per the requirements
Node mcu
Bo moter 4
Moter dirver
Battrey
Step 1: Do Connection As Par Given
Step 2: CODE
/* Simple WiFi-controlled car on ESP8266
* and L9110S motor drive board
* by Alan Wang
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
// WiFi settings
#define SSID_AP "ESP8266_WiFi_Car" // AP server name
#define PASSWORD_AP "12345678" // AP server password
// motor settings
#define RIGHT_MOTOR_PIN1 4 // pin 1 of right motor (D2)
#define RIGHT_MOTOR_PIN2 5 // pin 2 of right motor (D1)
#define LEFT_MOTOR_PIN1 12 // pin 1 of left motor (D6)
#define LEFT_MOTOR_PIN2 14 // pin 2 of left motor (D5)
#define RIGHT_MOTOR_SPEED 1023 // speed for right motor (0-1023)
#define LEFT_MOTOR_SPEED 1023 // speed for left motor (0-1023)
#define LED_PIN 2 // built-in LED (D4)
IPAddress local_ip(192, 168, 4, 1); //IP for AP mode
IPAddress gateway(192, 168, 100, 1); //IP for AP mode
IPAddress subnet(255, 255, 255, 0); //IP for AP mode
ESP8266WebServer server(80);
int car_mode = 0; // set car drive mode (0 = stop)
// initialize
void setup() {
Serial.begin(115200);
Serial.println("ESP8266 Wifi Car");
pinMode(RIGHT_MOTOR_PIN1, OUTPUT);
pinMode(RIGHT_MOTOR_PIN2, OUTPUT);
pinMode(LEFT_MOTOR_PIN1, OUTPUT);
pinMode(LEFT_MOTOR_PIN2, OUTPUT);
pinMode(LED_PIN, OUTPUT);
car_control(); // stop the car
WiFi.mode(WIFI_AP);
WiFi.softAPConfig(local_ip, gateway, subnet);
WiFi.softAP(SSID_AP, PASSWORD_AP);
// setup web server to handle specific HTTP requests
server.on("/", HTTP_GET, handle_OnConnect);
server.on("/forward", HTTP_GET, handle_forward);
server.on("/backward", HTTP_GET, handle_backward);
server.on("/left", HTTP_GET, handle_left);
server.on("/right", HTTP_GET, handle_right);
server.on("/stop", HTTP_GET, handle_stop);
server.onNotFound(handle_NotFound);
//start server
server.begin();
Serial.println("ESP8266 car server started.");
digitalWrite(LED_PIN, LOW);
// handle HTTP requests and control car
void loop() {
server.handleClient();
car_control();
// HTTP request: on connect
void handle_OnConnect() {
car_mode = 0;
Serial.println("Client connected");
server.send(200, "text/html", SendHTML());
// HTTP request: stop car
void handle_stop() {
car_mode = 0;
Serial.println("Stopped");
// HTTP request: go forward
void handle_forward() {
car_mode = 1;
Serial.println("Go forward...");
// HTTP request: go backward
void handle_backward() {
car_mode = 2;
Serial.println("Go backward...");
// HTTP request: turn left
void handle_left() {
car_mode = 3;
Serial.println("Turn left...");
// HTTP request: turn right
void handle_right() {
car_mode = 4;
Serial.println("Turn right...");
// HTTP request: other
void handle_NotFound() {
car_mode = 0;
Serial.println("Page error");
server.send(404, "text/plain", "Not found");
// control car movement
void car_control() {
switch (car_mode) {
case 0: // stop car
digitalWrite(RIGHT_MOTOR_PIN1, LOW);
digitalWrite(RIGHT_MOTOR_PIN2, LOW);
digitalWrite(LEFT_MOTOR_PIN1, LOW);
digitalWrite(LEFT_MOTOR_PIN2, LOW);
break;
case 1: // go forward
analogWrite(RIGHT_MOTOR_PIN1, RIGHT_MOTOR_SPEED);
analogWrite(LEFT_MOTOR_PIN1, LEFT_MOTOR_SPEED);
break;
case 2: // go backward
analogWrite(RIGHT_MOTOR_PIN2, RIGHT_MOTOR_SPEED);
analogWrite(LEFT_MOTOR_PIN2, LEFT_MOTOR_SPEED);
break;
case 3: // turn left
break;
case 4: // turn right
// output HTML web page for user
String SendHTML() {
String html = "<!DOCTYPE html>";
html += "<html>";
html += "<head>";
html += "<title>ESP8266 WiFi Car</title>";
html += "<meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">";
html += "<style>body {background-color: Moccasin;} h1 {color: SaddleBrown;} h2 {color: Olive;}</style>";
html += "</head>";
html += "<body>";
html += "<div align=\"center\">";
html += "<h1>ESP8266 WiFi Car</h1>";
html += "<h2>Press \"stop\" after the server has been reset</h2>";
html += "<br>\n";
html += "<form method=\"GET\">";
html += "<input type=\"button\" value=\"Go forward\" onclick=\"window.location.href='/forward'\">";
html += "<br><br>\n";
html += "<input type=\"button\" value=\"Go backward\" onclick=\"window.location.href='/backward'\">";
html += "<input type=\"button\" value=\"Turn left\" onclick=\"window.location.href='/left'\">";
html += "<input type=\"button\" value=\"Turn right\" onclick=\"window.location.href='/right'\">";
html += "<input type=\"button\" value=\"Car stop\" onclick=\"window.location.href='/stop'\">";
html += "</form>\n";
html += "</div>\n";
html += "</body>\n";
html += "</html>\n";
return html;
