Footswitch for Pandora PX4&(it Works)
Intro: Footswitch for Pandora PX4&(it Works)
Multi Effects Korg Pandora PX4 , a multi effects pocket, was not designed to be played in the stampede, the difference with his young brother PX 5 that is already provided for footswitch line ... but with improvised tools and materials, we can make yourself a footswitch for Korg PX4 Pandora .. enough to provide the following tools and materials.and this is the footswitch for pandora PX4 from Indonesia
STEP 1: Tools and Materials
tools: n tin solder, guting, cutter, screwdriver +, etc.
materials: nokia express music female jack 3.6 mm., Headset nokia express music, push-on switch for latch 2 Pcs, anda case/box, as shown below
STEP 2: And Step by Step Go Round As Follows:
First unloading PX4 like the following picture
Note: be careful in unpacking
STEP 3: Solder Wires According to the Following Picture
Second, take the female jack nokia express music, and main board PX 4, and solder wires according to the following picture
Note: be careful in soldering not to damage other components, use solder with a pointed tip, n so sorry forgot to photograph a result of her spirits until solderannya, but the diagram above is an actual happening
STEP 4: Third, Loading .. Nokia Headset and Cord to Connect to the Four Push-on Switch, As Shown Below
Note: The order of the cable may be different on each headset, to make sure, use a multi tester to know cable channels to the 3.6 mm jack with 3 bracelets again .. sorry no actual photos, but the picture above is an actual scheme that occurred.
STEP 5: Fourth, Push-on Switch Cluster in a Box (to Taste) Like the Following Picture
Fourth, push-on switch cluster in a box (to taste) like the following picture
STEP 6: Fifth, Re-PX4 Raft, Do Not Forget to Add a Footswitch Jack Hole in the Casing for PX4, and TADAAAAAAAAAA .... So Is a Foot Switch for the Korg Pandora PX 4
And now my Korg PX4 Pandora bias are invited on stage
IMPORTANT: before turning on the PX4, make sure all the jacks are connected
and this is the one and only footswitch for pandora PX4 from indonesia
3 Comments
toncat 9 years ago
Thanks for this. Would you mind providing more detail of how to disassemble the px4? What do you need to do after removing the one visible screw?
oscars4 9 years ago
thank you very much, I'm trying
momon_crot 9 years ago
