Introduction: Ford F250 F350 Smoked Lens LED Side Mirror Lights Tutorial
This is an installation guide for the smoked lens LED side mirror lights, fit for the 2003-2007 Ford F-250 and F-350, as well as the 2000-2005 Ford Excursion. Upgrade your OEM side mirror light with the LED side mirror light with smoked lens for a sleeker look and higher visibility.
Step 1: Remove the Back Casing of Your Ford's Side Mirror.
You can use your hands or a pry tool for this step. Be sure you don't pull too hard.
Step 2: Disconnect the Socket From the OEM Side Mirror Light.
Step 3: Undo the Lock to Release the Side Mirror Light From the Back Casing.
You can use a pair of pliers for this step.
Step 4: Install the Smoked Lens LED Side Mirror Lamp in the Reverse Order You Removed the OEM Counterpart.
Lock in the LED side mirror lamp to the casing. Plug the socket adapter into the LED lamp's socket.
Step 5: Put the Casing Back Onto Your Side Mirror.
You can now enjoy your Ford truck's new smoked lens side mirror lights!
You can shop for this and more truck accessories and lighting in our online shop today!
