Introduction: Ford Ranger 2.5" Leveling Kit Install 2019-2022
Freddy from PoorManMods shows you how to install a Rough Country 2.5" Leveling kit for the 2019-2022 Ford Ranger
Step 1: Remove Skit Plate
Remove the 4 skid plate bolts
Step 2: Disconnect Power Steering Connectors
Disconnect the 3 connectors
Step 3: Remove ABS Sensor & Brake Hose
Remove ABS sensor bracket and sensor, then the brake hose bracket
Step 4: Disconnect Sway Bar & Tie Rod
Disconnect the tie rod and sway bar from steering knuckle
Step 5: Disconnect Upper Ball Joint
Disconnect upper ball joint from steering knuckle
Step 6: Remove Upper and Lower Strut Nuts
Remove the 2 bottom and 3 top nuts securing the strut
Step 7: Remove Strut
Use a pry bar and push down on the lower control arm to remove the strut
Step 8: Remove Strut Studs
lightly torch the lower strut bolts and hammer them out
Step 9: Install Strut Spacer Studs
Install the provided studs into the strut spacer
Step 10: Install Spacer Then Strut
Install the spacer onto the top of the strut with the 3 factory nuts, then place the strut back into the truck
Step 11: Install Lower Bolts
Install the 2 lower strut bolts, lightly tap them into the strut until they stop, then spray some lubricant onto the splines. Install the 2 nuts on the bottom and tighten them to draw the bolts through the strut and properly tightening them.
Step 12: Connect Upper Ball Joint
This part can be tricky, but pull down on the upper control arm and install the nut onto the ball joint
Step 13: Install Strut Top Nuts
Install the 3 provided nuts onto the strut studs
Step 14: Reconnect the Rest
Finally, reconnect the tie rod, sway bar, brake hose and ABS sensor.
